I've got a problem with the hydraulics/suspension(?) of my xantia sx hdi (w reg)
I can get it to raise to the highest and drop to the lowrider but when i choose either normal setting it only ticks reasonably rapidly.
Has anyone encountered this?
I've read a lot about accumulators and spheres but i'm no mechanic. Is it just a case of changing the rear one, seems strange that it can do both extremes!?
The ride is also extremely hard on both settings
Matt
Xantia suspension hard & not able to choose "middle
dodgy123
Citroen Xantia SX hdi "2000"
- x 94
hi Matt and welcome
firstly if you can not get the car to sitt at either of the middle setting in between full up and full down, this sounds like one of the nylon hight corector links have poped off,
the cause of this is the H/C linkage mechanisum seizeing up, these are the two turrets on the H/C carrier/caridge and they are ment to be very free moveing,
the only long term fix is remove the H/C carridge lube and work the turrets till they are floppy loose, then re/fit and fit a new nylon link as the old one almost certainly will not stay in place for very,
the ticking is usualy the regulator sphere is low or out of gas (needs replaceing ) which is on the front of the gear box, this or either centre sphere will not improove the softness of the ride,
if the ride is still hard after the H/C is functioning correctly you will need to start replaceing the cornner sphere's, which the main culprit for hard ride (so long as the H/C's are working properly,
you could always as Jim (citrojim) if he has the time to check it out for you if he dosent mind as he is in your area,
regards malcolm
regards malcolm
regards malcolm
regards malcolm
- x 8391
It's quite normal with a seized height corrector to be able to do both extremes as the manual height control acts on a different part of the mechanism.
Here's a diagram of both front and rear correctors:
Also, if the corrector is seized, the ride may be less than good. Spheres also may be past their best.
The tick you have heard about is the interval between the pressure regulator cutting in and out like a thermostat to regulate the main system hydraulic pressure. A short tick rate (less then 30s) normally indicates a tired accumulator sphere or a heavy internal leak.
I'm in Newport Pagnell. Sadly, present circumstances dictate that I am unable to take on any work for the foreseeable future.
dodgy123
- x 8391
Motorserv in Old Wolverton is good if not a tad pricey Matt.dodgy123 wrote: What's the best place locally for parts? Or am I better going online?
ECP have a branch in Bletchley, near the H8/V4 roundabout. Rarely use them though.
Generally though, depending on what you need, GSF is hard to beat.
falling-out-with-my-car
- x 25
Pleiades, charged £79 plus fitting, (labour prices are very reasonable) for the complete rear height corector unit after mine completely seized last New years eve.
your not to far away from Pleiades in Milton keynes.
have you got breakdown cover with the AA or Rac etc they could be pursuaded to lift the car over there for you.
I am 35 miles from Pleiades but auto-home still took my xantia estate on a flatbed truck over there for me.
maybe it would be worth borrowing a car transporter trailer if you dont feel competent at doing the job yourself?
regards Nigel.
regards Nigel.
- x 8391
- x 25
Jim,
do you reckon thats a safe bet then with only the depth of your tyres as suspension?
the roads around sawtry are smooth but going through sawtry they are pretty rough badly maintained country lanes. take a bottle of milk with you and when you get there you can have a milkshake.
regards Nigel
regards Nigel
