lost power - ESP...
hdi_man
lost power - ESP...
Unread post by hdi_man »
well had the car 2 weeks now with no issues...
then this morning pulling away from some traffic lights the power went...I thought I had hit speed limiter or something, then something about ESP flashed up. I stuck hazzards on, and restarted the engine, everything was OK and I pulled away.
I'm worried that the car has the common issue I have read about now ! :cry:
logiclee
Unread post by logiclee »
What common issue?
Cheers
Lee
2009 C5 2.0HDi Exclusive Auto. Storm Grey.
hdi_man
not sure if its the new C5 but previous ones had some ESP / DPF loss of power issue I think
Citroenmad
x 110
Unread post by Citroenmad »
Ive never heard any loss of power problems on the C5 II. Ours has been no problems at all and the traction control shouldnt effect power.
Doesnt ESP keep the car in a straight line if it detects a slide? So i wouldnt have thought that should effect pulling away.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
mooseshaver
Unread post by mooseshaver »
C5s and probably other cars will disable the ESP/Traction control when the engine goes into limp home mode. I guess Limp mode cannot fiddle with the torque to the wheels?
I think they use the abs and a reduction of power if the wheels spin to get the wheel to grip?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Citroenmad
x 110
I didnt think that the traction control effected the power, it just applies brakes to the spinning wheel and in theory you should get on your way. Im sure that is what our C5 with ESP/traction control does anyway.
03 Seat Arosa 1.0S
meexi
Unread post by meexi »
surely that is your esp cutting in and dropping the power to reduce wheel spin?
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
mooseshaver
The Bosch website has some info. It can Accelerate the driven wheels. Ooh magic. It's like it can drive itself.
Gone cars.
cachaciero
x 9
Unread post by cachaciero »
The ESP / ASR i.e traction control system will fail if cannot get Torque data from the engine ECU, there may be other data as well but I do know that Torque is one bit of data required. Certainly on the 2.2 C5 and I believe others an engine failure that goes into LIMP mode will cause the ESP / ASR system to fail because either the data is not valid or maybe not computed at all.
I would believe that the above would be true for most cars that have traction control.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
