Tyre Pressure Sensor and Manual
TheOne
Unread post by TheOne »
Hi
I have recently bought a 2001 C5 2.2 Exclusive estate with 83000 on the clock. It's a superb car to drive and in incredible condition. However, it has a tyre pressure sensor missing. My questions are:
1) Do I have to get a specialist garage to fit one?
2) How much 'roughly' will it cost?
3) Anyone recomend a garage. I live in Portsmouth and work in Southampton.
Also, can anyone point me to a site that has explanatory information on how the controls on the stalks and trip copmputer works? I do have the booklets that came with it but they are light on explaination.
Fanx.
DHallworth
x 167
Unread post by DHallworth »
If they are the same as the C6 then the sensors themselves are around £60.
They also need coding to the ECU which I was getting quotes of around £110 to do.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
JohnD
(Donor 2022)
x 72
Re: Tyre Pressure Sensor and Manual
Unread post by JohnD »
TheOne wrote:Hi
Have a look here. They seem to be around 25+Vat quid. You'll need to find a Lexia to introduce a new sensor to your car.
http://www.tyre-equipment.co.uk/acatalo ... alves.html
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
cachaciero
x 9
Unread post by cachaciero »
DHallworth wrote:If they are the same as the C6 then the sensors themselves are around £60.
David.
They won't be the same as the C6. The BSI will need to be programmed with a Lexia AND part of this requires another tool to make the sensor "talk" such that the BSI can recognise it. There have been a few posts on this subject over the last six months or so a search should throw something up.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Kowalski
Unread post by Kowalski »
If you have a post-facelift C5, the sensors are the same as the C6, 407 etc, pre-facelift C5s use different sensors, they're much cheaper than the later sensors.
The later system on the post facelift C5s is more sophisticated, it can tell you which tyre is deflated which I believe the earlier system couldnt it could only tell you one tyre was deflated.
JohnD
(Donor 2022)
x 72
C5's from August 2004 use these ones:-
65396-67 Tyre Pressure Sensor Valve for Citroen
Price: £49.00 + VAT.
VDO part ref S180014805Z. Citroen C5 II, C4, C6, C8; Alloy wheels. Requires diagnostic reprogamming for the car's onboard TPMS system to recognise a new valve.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
cachaciero
x 9
JohnD wrote:C5's from August 2004 use these ones:-
The first line of the OP says "I have recently bought a 2001 C5 2.2 Exclusive estate"
so why confuse him with C6's facelifted C5' etc.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
x 1938
Unread post by Paul-R »
cachaciero wrote:There have been a few posts on this subject over the last six months or so
This is the one I think you mean
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28552
