Hi All
My dad has a 1999 406 2.0 HDi (110) with the engine management light on, I have come over to visit (he lives in france) and read the fault with PP2000, fault came up as Intermittent fault Accellerator pedal signal 2. coherance with accellerator pedal signal 1.
I cleared the fault and when the engine was started the light was out, soon as i revved the engine on it came.
Before clearing the fault the engine was revving with a mind of its own.
Any ideas as to what it is?
Also it says there is a fault with the preheat system, is there a common failing point on these?
Rob
406 2.0 HDi engine management fault
h2ocooler
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
h2ocooler
Can anyone help please, need to get this sorted out before I go back home.
Rob
Rob
h2ocooler
Also how much movement should there be on the engine mounts, not had chance to look yet but i think the bottom mount may be broken, the engine is swinging around like mad
Rob
Rob
DickieG
- Monaco's youngest playboy
- x 38
On a xantia HDi of the same year that fault can be triggered by pressing the brake and accelerator pedal at the same time, is the brake pedal switch working OK? i.e. are the brake lights illuminated continuously?h2ocooler wrote:My dad has a 1999 406 2.0 HDi (110) with the engine management light on, I have read the fault with PP2000, fault came up as Intermittent fault Accellerator pedal signal 2. coherance with accellerator pedal signal 1.
I take it the 406 is similar to a Xantia HDi, if so check the mount that attaches to the suspension strut/inner wing, a common failure.h2ocooler wrote:Also how much movement should there be on the engine mounts, not had chance to look yet but i think the bottom mount may be broken, the engine is swinging around like mad
Rob
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
h2ocooler
Will look to see for sure tomorrow but think the brake lights are working ok.
When I looked on PP2000 the throttle was always at 4%, I did wonder if the cable needed adjusting.
Rob
Rob
