hydraulic pump
i3
hydraulic pump
Unread post by i3 »
hy all, just wondered,, i was interested in finding out a little about the hydraulic pump,, which one is the correct application for the 2.1td vsx 1997?
are the 2.1td and 1.9td hydraulic pumps interchangeable? are any of the different engine model pumps suitable for the 2.1td?
thanks
x 8397
I think 1.9TD and 2.1TD pumps are interchangable. If they look identical they will be.
Why do you ask?
i3
Unread post by i3 »
well...im not sure,,, i noticed that there was a leak coming from my car...looking at it from the front,,you can see it signs of a leak on the ground beneath the left-side(drivers-side) of the engine bay...when i had a look... i didnt give it a proper or thorough check though,,, i noticed lhm on the hydraulic pump...so im thinking,,,it may be at fault...im not sure...
i was looking at pump prices to get a rough idea,,i saw one removed from a 1.9td for £15ish,,,so i thought if it is suitable i may as well get it just in case,,and if my pump turns out not to be at fault, then, there may be someone else on the forum or something that may want it....
is that cheap price?
x 8397
If it's leaking in the vicinity of the large 19mm hexagon where the left-hand delivery pipe exits then it is a very cheap fix indeed. You just need an O ring from the stealers. They cost pennies. It's a very common problem.
Odds on it'll be that. Clean the pump up and then observe...
i3
Unread post by i3 »
hope it will be just that then...il have a proper check this afternoon hopefully.
oh,,i actually meant the lhm was leaked out,not on to the pump,but on the thing right below it,the alternator...i think?
x 8397
Yep, that is the alternator and indeed, the last refuge of LHM that has leaked from the pump.
Good idea to sort it as LHM and alternators don't get on too well. Sooner or later it may kill the alternator.
Give the pump a good clean up. (I use brake cleaner and then blow-dry with an airline) and very soon you'll see exactly where the leak is coming from. Pay particular attention to the 19mm hex thread. If this is weeping you'll soon see a teardrop of LHM forming.
Xaccers
x 188
Unread post by Xaccers »
there's also a 19mm blank further around the pump, this can sometimes leak so it's worth getting 2 o-rings and changing that one as well anyway.
DIY sphere tool
x 94
Unread post by citronut »
and be aware there are two diferent sized seals on one pump,
regards malcolm
Xaccers
x 188
yes one size for the 19mm hex that leak and one size for the torx that don't tend to leak
DIY sphere tool
fifth_cit
Unread post by fifth_cit »
This could be the problem that is occurring with my sons Xantia. When changing these seals does the system need de-pressurising first ?
C5 III Tourer 2.0HDi SX
Previous Citroens:-
05 C5 Facelift VTR 2.0Hdi
03 C5 LX 2.0Hdi
51 C5 LX 2.0Hdi
96 Xantia LX TD
x 8397
Yes, it's not a bad idea to. Even then you'll get a good loss of LHM.
I find it's good to pop a sheet of polythene under the filler cap on the LHM reservoir to create a bit of a depression to keep as much LHM in as possible.
Then, and this is very important, protect the alternator from LHM spills by covering it. I have found a nappy works well as it will both cover the alternator and catch spilt LHM.
Undo all the "P" clips on the pipe and undo using a 12mm flare nut spanner. Gently tease it out of the way. Then undo the 19mm hex. Take it carefully and slowly and in doing so you'll not dislodge the ball and spring underneath it.
i3
Unread post by i3 »
Jim, i had a little look at the pump today... it was all pretty dry, the alternator and pump,,no leaked lhm,, i dried with a towel anyway,,,i couldnt see any leaks coming through,,,so i started the car and when i then looked,,there was a small amount of lhm on the top of the alternator toward the left side of it which looks as though it leaked from the bottom of the pump,,, but,,,this did not increase,,i left the car on a little while,,nothing,,so i turned off,,wiped it up,,no leaks that i can see,,,so i started the car again,,still couldnt see any leaks,,,even from where it just leaked from earlier,,what should i be looking out for? where exactly?...ok,,,underneath th car however,,is the usual signs of leakage,,,there are two areas on the ground where lhm is leaking to....you know underneath the car on the drivers side,,there is that small section of underpanel or whatever it is called,,,its basically under the hp pump,,alternator area,,and extends back to like roughly where the tyre is...well the lhm laks and leaves patches on the floor,,one towards the back of that underpanel thing and one towards the front,,,so basically one is pretty much under the hp pump alternator etc area,,,the other is near the tyre... the at the front of the car is smaller,,the one towards the tyre is larger...this keeps dripping,,but i dont know where from,,, i thought maybe it is just the fluid leaked onto that underpanel thing...? but im not sure... ....what is the thing under the alternator? it maybe leaking from there...? i have also noticed that it also has the belts attached to it,,,and the pulley attached to it spins slowly,,really slowly and inconsistently,,while the belt attached to it is spinning normal speed...is that supposed to be?
andmcit
x 30
Unread post by andmcit »
Odds on the thing sitting under the alternator with belts and pipe feeds is
your air conditioning pump and it will turn at speeds independant of the
engine as there's a clutch on the pulley.
The leak is likely the o ring seals on the main high pressure feed pipes
or the low pressure rubber feed pipe.
Andrew
i3
Unread post by i3 »
where exactly are the main high and low pressure pipes located? any diagrams or images would help alot...thanks
andmcit
x 30
The x2 high pressure are the metal pipes on the cylinder body of the
pump pictured with slight turquoise colouration in the following picture:
IIRC this is a picture posted on Flickr by Deian.
Another cross section shows the feeds in/out:
The high pressure is number 1 and the low pressure is 3.
The seal is number 5 in this diagram:
Andrew
