banging noise
sijrayner
banging noise
Unread post by sijrayner »
will check tonight but does anyone know what a loud metallic clang might be when i pull away. i assume it is something to do with suspension. maybe a strut bush gone south or similar. noise comes from the rear, it occurs as i move off, then nothing, although i think i may have heard it again when i went round a roundabout.
any thoughts ??????
why oh why did i buy a C5.
Citroenmad
x 110
Unread post by Citroenmad »
How many miles has your C5 done?
Could possibly be a rear radious arm bearings, thats possibly the worst case. Usually casues a cracking noise, though usually over bumps.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
sijrayner
hhmmm, 140K miles. i don't like the sound of the comment "worst case" sounds expensive.
cachaciero
x 9
Unread post by cachaciero »
sijrayner wrote:hhmmm, 140K miles. i don't like the sound of the comment "worst case" sounds expensive.
Evidence both in this forum and others would indicate that this is quite a common failure after about 70K, in my case 95K.
There have been several threads in this forum discussing the repair of the bearings and the "gotchers" well worth reading if contemplating DIY.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
sijrayner
thank you my friend.
Xantidote
x 5
Unread post by Xantidote »
I'd check it's not something simple like exhaust hitting the body. Fingers crossed :)
Martin
1995 Xantia TDLX (deceased :( )
Citroenmad
x 110
Yes, check obvious things first.
I wouldnt have thought you would get a radious arm bearing to make a noise when pulling away, unless your being agressive with it and the car is really dipping.
OUr previous C5 estate had a bearing go, it caused very loud cracking noises when running over bumps. The sound was very bad and it spread through the car, i thought it was the front at first as the cracking could be felt through the floor. It started suddenly.
Its not a major job though.
03 Seat Arosa 1.0S
sijrayner
Xantidote wrote:I'd check it's not something simple like exhaust hitting the body. Fingers crossed :)
got that as well, assume it is a badly fitted one, need to do that at same time.
sijrayner
Citroenmad wrote:Yes, check obvious things first.
had a thought, has anyone heard of anything like this being caused by a brake related problem, it's a bit of a tinny noise really and seems to occur when the rear brakes are releasing, i know i need to get the car up and check.
boristhespie
x 4
Unread post by boristhespie »
Bit tinny was like mine. It started off small and the grew into a major clatter over three years.
Best to get the radious arm bearing checks ASAP as play can wear the inside of the bearing housing and cause real damage.
I was advised by a number of garages when they eventually found out what it was that I may as well buy a new car!
Up to that point dealers and specialist were unable to find the noise, so if you take it to garage mention radious arm bearing.
It cost me £275 to have them replaced which was less than a new car. But get it checked soon.
C'est pas possible!
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Some years ago when I had my Xantia I had a bang - maybe more of a loud click when driving off. I discovered it was caused by a loose brake pad hitting the far end of the slot.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
sijrayner
obviously hopeful, but this sounds like something i will check before ripping into bearings, brakes have always been really squealing so hoping dodgy pad alignment
