Hi.seen to be getting a rumbling noise on highspeed braking 60mph plus,there is no wheel bearing noise,all suspension etc is in good order,ive just whipped a FRONT AND BACK wheels off and the FRONT pads are low,REARS FINE .........would this be the cause?....
any thoughts would be great..ps X reg HDI
XANTIA;RUMBLING NOISE ON HIGH SPEED BRAKING
HDI
- x 7
Heavily worn front pads will cause that sort of noise.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
mark21td
Could be slightly worped disces, Think I'd replace the disces and pads (as pads are low anyway), if that doesn't sort it then at least you know the breaks are fine.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
cox377
d3xt0r
