aircon regassing port
c.morewood
x 55
Unread post by c.morewood »
I'm considering doing a regas of my Xanta's aircon with a leak sealer. It hasn't worked for about 9 months. So I've got a couple of questions.
Where is the regas port?
Are there any checks I should do beore the regas?
Thanks in advance.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
KP
x 27
Unread post by KP »
I think on the HDI's as with others the AC compressor and regass ports are only getable from under the car so if you have an undertray you need to take that off first and then hook up your regasing unit.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yes, the regas ports are on the in and outlet pipes under the front...
Put the car on high, then for safty support the car with axle stands then - if fitted remove the under tray, then you will see the compressor at the bottom with two large pipes comming from it and TWO ports!
If you have a quick release adapter it should ONLY fit the Low side re charge port.. as the high pressure port is a different size..
Paul
A very sad...
1994 XM 2.1 d auto
c.morewood
x 55
Thanks Guys.. I'm heading down South this summer and it looks as though I'll need the aircon.
Is there ayway I can check for leaks before using the regas?
'94 Fiat TipoTd 40K
h2ocooler
Unread post by h2ocooler »
Only if you have the gauges or go to halfrauds and buy a regas kit with a gauge on it, give "some" indication of how much is in there but not really accurate.
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
DoubleChevron
Unread post by DoubleChevron »
h2ocooler wrote:Only if you have the gauges or go to halfrauds and buy a regas kit with a gauge on it, give "some" indication of how much is in there but not really accurate.
You can't tell how much is in there unless you recover the refrigerant and weigh it. Most likely it's "close enough" if the low side is around 35psi with the system fully loaded .. ie: interior fans running full bore with the air-con on (depending on the refrigerant used) the high side will depend on the anbient temperature and condensing capacity. I can get the high side way over 200psi on 40degree days in my CX for example (that I've put the hugest most efficient condenser I can find in).
If you can't find the service ports, you can use the shraeder valve under the pressure sensor. You should be able to unscrew you quick release R134a fittings to expose the standard shraeder valve R12 fitting on your gauge/manifold set.
seeya,
Shane L.
'96 Big BX 2.1TD exclusive slugomatic (aka XM)
'85 CX2500 GTi Turbo Series II (whoo hooo)
'96 Xantia VSX slugomatic (sold !!)
and of course, lots of old Citroens, slowly rusting away in pieces ;)
