Cabin temp sensor (Xantia)
mark21td
Unread post by mark21td »
Does anyone have a cabin temp sensor (the one with the little fan inside) going spear ?
It's for my Xantia 1.9td VSX 1997.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Ill have a look in the spares department (aka shed) :) .
Its a little bit full now ive sold my other spares department (caravan) so it may take a couple of days to get to the back where im pretty sure there is one :lol:
Colin
mark21td
Thanks Colin.
admiral51
(Donor 2026)
x 391
I havent forgotten,just plucking up the courage to empty the shed :oops:
Colin
mark21td
No problem Colin, it's not really an ishu in this weather.
admiral51
(Donor 2026)
x 391
Hi Mark
Sorry to report that having emptied both stores departments i only have the grille for the sensor fan and not the actual fan itself :oops: :oops:
If memory serves me right i think i may have let it go to another forum member a couple of years ago, help me out here Mike T please :?
Colin
mark21td
No problem mate, thanks for spending the time to look.
MikeT
x 232
Unread post by MikeT »
admiral51 wrote:If memory serves me right i think i may have let it go to another forum member a couple of years ago, help me out here Mike T please :?
If it was when you gave/sold me a bunch of parts - parcel shelf, radio, etc - then yes I was in need once and could have been the benefactor but I can't recall it specifically.
As for the OP's request - Mark, what's wrong with the original unit as it might be a simple fix?
mark21td
It's been diegnosed as faulty by DickyG's Lexia, it's the temp sensor part I think, but the fan doesn't always work (until I give the dash a whak) so I'm looking for a compleat unit.
x 1488
They have a bit of a limited life, and any second hand ones are likely to be in a similar state to the one you've got.... if the car's a keeper I'd be tempted to buy a new one - but they are the thick end of a ton.... :cry:
MikeT
x 232
It's just a small fan that draws the cabin air over a simple thermistor. I imagine it'd be relatively simple to replace both from off-the-shelf parts if only we knew what the thermistor value is (or are they universal?). As RichardW advises, when I looked a few years ago, a new one was over £80!
