My 2001 Synergie Hdi developed a fault last night,when I started it a metallic sort of grating noise was coming from the aux belt area,the ignition light was also on,I had to drive home so took a chance,a few 100yds down the road I felt a slight surge and the noise had gone and the ignition light went out,I carried on for a few more miles and after I had braked quite sharply the noise started again and the ignition light came back on,after a few 100yds it cleared again and was fine for the rest of my journey of about 45 miles,I started it today and no noise,I had assumed the altenator to be at fault but have noticed on some other threads that the crankshaft pully can be worn,any thoughts ?
Ray
Hdi crankshaft pully
Xantidote
- x 4
"a metallic sort of grating noise"
From my reading of HDI issues on the Forum, if I were you, I'd be checking it out pretty quick, partly to check out how serious it is, and partly to avoid risk of breakdown, with the added potential risk of further damage to engine. Once you've identified the problem, you know what the risks are of not fixing it immediately. Not sure I'd want to use the car until prognosis complete - hope it's easily fixable
Martin
1995 Xantia TDLX (deceased
dieselnutjob
racingraymond
