2008 C5 DRL's
Post Reply
hdi_man
My Cars:
2008 C5 DRL's
Post by hdi_man »
apparently the new C5's have Daytime Running Lights fitted but not activated, anyone done this yet ? guy on ebay selling a wiring loom for £15 that activates them
to change the DRL bulb to an LED type you have to remove the bumper though...
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Re: 2008 C5 DRL's
Post by JohnD »
My C5 is a MkII and I've recently changed my sidelights to LED and Yes! I had to take the bumper off.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
hdi_man
My Cars:
Post by hdi_man »
what kind of LEDs did you use , CANBUS ones that don't give warnings ?
Citroenmad
My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10
x 110
Post by Citroenmad »
hdi_man has the new germanic C5 III which will be different from the facelifted C5 II.
Dont know about the running lights, is it not just a option on a lexia?
Dont like day time running lights myself.
19 Hyundai i10
Trainman
(Donor 2018)
Lexia Available: Yes
My Cars: 2008 C6 2.7 Exclusive in Mativoire Beige with Vitali Leather.
2017 1.6HDi Berlingo Van - the works van
x 42
Contact:
Post by Trainman »
DTL should be an option from the configuration menu via the on board computer
Steve
http://c6owners.org/index.php
logiclee
My Cars:
Post by logiclee »
Trainman wrote:DTL should be an option from the configuration menu via the on board computer
Nope the option is not given to enable them on the UK C5 menu.
Cheers
Lee
2009 C5 2.0HDi Exclusive Auto. Storm Grey.
logiclee
My Cars:
Re: 2008 C5 DRL's
Post by logiclee »
hdi_man wrote:apparently the new C5's have Daytime Running Lights fitted but not activated, anyone done this yet ? guy on ebay selling a wiring loom for £15 that activates them
Bought that myself and have it fitted. Took me 5 minutes but I am an electrical engineer. It's a simple job, one fuse to replace and one wire to scotch lock onto the DRL lights wire behind the headlight.
I actually located the correct wire down by the battery and scotch locked it there as it's now invisible.
DRL's now come on with the ignition but they stay on when the headlights are which they wouldn't do if the menu was enabled.
I've been looking to replace the halogen HP24 bulb with an LED bulb but I've only been able to find a French forum with the info and my French isn't good. It looks like they are saying a 12V G4 LED will fit so I may have a look.
Cheers
Lee
hdi_man
My Cars:
Post by hdi_man »
cheers Lee sounds good mod. let me know if you find suitable LEDs. someone on here used the Audi LED strip LEDs on the older C5's not sure I want that look though.
something like this on the insignia looks good :
http://autodesigncorner.blogspot.com/20 ... oming.html
Citroenmad
19 Hyundai i10
x 110
Where are the DRL on the new C5 headlamps?
So long as they are not like the Audis which make the car squint every time the indicator is on :lol:
19 Hyundai i10
hdi_man
My Cars:
Post by hdi_man »
here is the link and photos :
http://cgi.ebay.co.uk/Citroen-C5-Daylig ... 092wt_1026
all I want to do is enable then change to LEDs
KP
My Cars:
x 27
Post by KP »
Question remains,
Can it be enabled with a suitable lexia at all??
Citroenmad
19 Hyundai i10
x 110
Is that just the sidelight illuminated and not a seperate light?
19 Hyundai i10
JohnD
(Donor 2022)
2018 Citroen C4-B7
2011 Citroen C1
x 72
Contact:
Post by JohnD »
hdi_man wrote:what kind of LEDs did you use , ?
LEDs with 433C offset bayonet fitting
http://cgi.ebay.co.uk/XENON-5-LED-H6W-4 ... 335b8d06a6
When they've been switched off, they continue to shine for 3 or 4 minutes.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
logiclee
My Cars:
Post by logiclee »
Citroenmad wrote:Is that just the sidelight illuminated and not a seperate light?
The new C5 has a standard 5W sidelight bulb situated in the high beam unit, the high beam unit in the innermost reflector with a H1 bulb. The dip beam unit uses a H7 bulb and then right at the far outermost of the headlights is another H7 bulb and small reflector for the corner lighting.
Under the headlight unit is the DRL which Citroen describe as having a HD24 bulb. I believe this is a two pronged type capsule halogen bulb.
The foglights in the lower bumper are H3's. The indicators are next to the foglights.
see most of that in this photo
Cheers
Lee
BrianM
My Cars:
Post by BrianM »
Maybe there were changes made to the menus but the DRLs on the 09 C5 can be turned on from the console - Vehicle Parameters, Lighting . It enables the lights under the headlights alright.
Brian
09 C5 Exclusive
Post Reply
