1996 ZX TD Estate - fuel gauge sender unit
cdbe
I have just bought a new sender unit to try and sort out an inaccurate fuel gauge but there is no hole to fit it in - there is a hole under the seat for the lift pump but not one for the sender unit - does this mean mine has a combined unit?
1996 Citroen ZX 1.9TD SX Estate
spider
- x 77
I'm not that familiar with these but (sorry if this is stating the obvious, but stranger things have happened) , have you looked under the other side of the seat ?
Some have the piping at once 'access hole' and the wiring for the sender etc at the other.
Andy.
cdbe
the_weaver
- x 94
on service citroen it shows two units fitted into the fuel tank,
one is the rheostat, the other they call a fule tank cover,
this sendor might not be the same part No. as the one you purchased,
and as Spider says it dose show two units fitted one each end on the tip of the tank,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
96055882 FUEL TANK COVER 36.73 GBP 43.16 GBP 43.16 GBP
0000152549 RHEOSTAT 69.71 GBP 81.91 GBP 81.91 GBP
regards malcolm
regards malcolm
