Xantia on ebay
Napoleon
x 4
Xantia on ebay
Unread post by Napoleon »
I don't need a new car, but it's good to keep up to date with prices/condition etc.
Anyone with a view on this LX 1.9?
Suitable for svo? (when did Bosch pumps stopped being fitted to Xantiae anyway? Or was is model-related?)
http://cgi.ebay.co.uk/citroen-xantia-d ... 500wt_1182
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
Xaccers
x 188
Unread post by Xaccers »
1.9TD's were fitted with bosch pumps.
1.9D's were fitted with a mix of lucas and bosch (if memory serves)
The rust on the driver's side rear wheel arch worries me.
A lot of estates get it where water gets between the inner and outer skins, but usually it's the near side that's worse (more puddles).
That much rust would have me wondering if there's been a minor prang there popping the skins apart (my previous LX estate had it so bad you could push a finger through the wheel arch).
DIY sphere tool
red_dwarfers
x 58
Unread post by red_dwarfers »
ANOTHER Xantia with an identity crisis!
I wonder why....linked to the rust maybe?
Kev
'19 C4 Cactus 130 Flair
Napoleon
x 4
Why, 'identity crisis', dwarf that is red?
Tim
2009 HV09 C5 2.2
Tarte au Citroen
red_dwarfers
x 58
Well Mr Tim, take a closer look at the front double chevrons, its an estate with a pre mid 1994 front end, estates were not produced before 1995. Also being an early front end, the chevrons should be on the bonnet whereas in this example they are on the front panel mimicking the moulded chevrons on later S1 Xantiae.
There have been few ebay Xantiae with interesting combinations of front ends, from one which had two lots of double chevrons (Pre 94 bonnet and Post 94 front panel) to one with no chevrons on the front at all!
EDIT: Personally if the owner was going to put the chevrons on the front panel I would have though it would be best to put them nearer the NS headlight for that S1 XM look :wink:
Kev
Xaccers
x 188
Front end shunt?
Wonder if it could have caused the rust to be that bad, in which case, I'd certainly not go near it!
DIY sphere tool
Napoleon
x 4
OMG, it's information like that that is priceless.
Guess which car I won't be buying this week!
Tim
2009 HV09 C5 2.2
Tarte au Citroen
Napoleon
x 4
Kev, why doesn't my 1995 Xantia have the chevrons on the bonnet, then? Because it's a saloon, and the 'rules' were different for them?
Tim
2009 HV09 C5 2.2
Tarte au Citroen
Xaccers
x 188
Napoleon wrote:Kev, why doesn't my 1995 Xantia have the chevrons on the bonnet, then? Because it's a saloon, and the 'rules' were different for them?
Chevrons moved to the better position by 95.
DIY sphere tool
Citroenmad
x 110
Unread post by Citroenmad »
I think 95 is too late for the chevrons to be on the bonnet, we had a 94 xantia which had the later grill.
Shame about the rust, but apart from that and the grill it looks pretty good, very low mileage and its a 1.9TD.
I know of a very early xantia estate, which despite having one owner from new and having no rear accidents its the most rusty xantia ive ever seen. Rear arches are almost hanging off. Fortunately its an odd brownly/red colour and doesnt show too much. Strangely it doesnt have electric front windows either.
Anyway, this look a reasonable car, however i do wonder why there is no pictures of the other side, sometimes a worry.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Synergietom
Unread post by Synergietom »
Guys do you think this would be a suitable donner car for the engine as im having so many problems at the mo with my synergie 19 td on the same plate i think it may be worth having a look i could allways strip the rest and ebay the parts.
Yipee i have the xant lets i hope i keep her this time
Chris570
x 36
Unread post by Chris570 »
it would have to be very cheap, i have a 1.9td engine that i've taken out of my 1995 xantia that can go cheap, i.e make an sensible offer and i'll accept
