Citroen.Service Price Check Please?
x 8386
Can someone with access to the live Citroen.Service please advise me of price/availability for Part. No. 4023 H2. That's the Activa-specific power steering supply pipe, the one with the flexible bit in the middle of it..
Mine's weeping at the rigid to flexi joint by the gearbox...
Else, anyone breaking an Activa?
Thanks :D
Toby_HDi
x 3
Unread post by Toby_HDi »
Jim, please sit down...
£136.90 inc VAT
:shock:
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 94
Unread post by citronut »
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00004023H2 HYDRAULIC TUBE 116.51 GBP 136.90 GBP 136.90 GBP
regards malcolm
x 8386
Thanks both :D
Actually, not a bad price for a complex pipe..
I now need to find out how much Pirtek will charge for a pattern one, that's if they can make a pattern one...
x 5670
While we are looking up prices you mind looking up the price and ID of the rain sensor for a phase 1 C5 please (2002 2.0 HDi SX Estate).
wheels nut
Unread post by wheels nut »
Here are the part numbers and prices for the rain sensor
part number 6405K0 up to RPO 9618 £112.96 inc vat
part number 6405Y5 after RPO 9619 £146.86 inc vat
x 5670
I think I will be making do without that!
Many thanks for taking the trouble though wheels nut :D
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Jim, equal of £261.87 here. :shock:
A good example of why I am always begging people to snag and post stuff!
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Jim, can this pipe be remade as a single copper contruction? I ask because the same pipe on the coupe is on my radar as being something to replace..
this has some solid sections and some flexi ones.. just wondered why a new version couldn't be bolted/held effectively under engine and not need to be flexible?
x 8386
Not really John, as the rubber flexi section also acts as a shock absorber/sort of accumulator...
I believe that applies to yours too. If it's all rigid, you'll feel lots of vibration through the wheel...
Clogzz
x 40
Unread post by Clogzz »
Could someone please look up the price of item 3, part 5270 RN ?
I can’t get prices from here, but they’re talking about $A600 / £370.
There’s a weep from the bundle, and I hope it’s the return pipe.
Thanks for your troubles. :D
KP
x 27
Unread post by KP »
Hi Clogz,
Price is as follows...
00005270RN OIL BACK HARNES 217.65 GBP 255.74 GBP 255.74 GBP
Looks like a local hydraulic place would make one up for a lot cheaper than that :)
Clogzz
x 40
Thanks Will, :D
The pipes are a bundle of three, and the weep is from inside a shroud that looks like it’s intended to prevent leakage onto the steering gaiter … as if they knew it was going to leak.
The return pipe is 10 cm from the exhaust manifold … just what we need in a hot country.
I’ve seen hoses rated to 350°C at a hydraulics place.
Thanks again for your troubles. Image
x 94
so are private person's still haveing prob's registering on service citroen ,
regards malcolm
x 8386
I've not tried in all honestly Malcolm as Laser give me what I want. It's only on very rare occasions I'm bothered about the cost of something...
