peugeot models
spliffy
peugeot models
as you probably know i have asked a similar question on the citroen section can any body tell me what models of peugeots have the xu 2.0l t engine in them cheers
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
spider
- x 77
Is that the 2.0 8v turbo unit ?
406 SRi for sure. The one with the 'interesting' seat and door panel trim.
Some 406 2.0 exec's, I cannot remember which way around, the first two years of production had the 2.0 8v turbo then they just used the normal 2.0 16v n/a, I though the other way around but I'm 99% sure its early (as in 96 and some 97) = 8v turbo, later than that = normal 2.0 16v n/a unit
Some 605's although I am not sure if the UK model had the turbo unit.
I do not think the 405 or 306 ever had this unit, certainly not from the factory. The rare Mi 4x4 405 had the 16v unit iirc.
Hope that's a bit of help.
Andy.
- x 8448
Absolutely Andy, the 405 Mi16 and 4X4 had the legendary Mi16 engine as found in the BX GTi 16V "Valver". The XU9J4 all-alloy unit.spider wrote: I do not think the 405 or 306 ever had this unit, certainly not from the factory. The rare Mi 4x4 405 had the 16v unit iirc.
A good few 306s have received the 2.0 CT as a transplant later in life though, along with some receiving a 3.0 V6
Designation of the 2.0CT is XU10J2CTE with the engine code of RGY (early) or RGX (Later) RGYs are usually found in pre-'96 cars and develop a little less urge than the RGX.
