Hello,
I fixed an exhaust pipe from my BX. Everything went fine until i replaced it with a new one.
After that i started my BX and it comes in the front at the highest level. Even now it is in there. It doesnt matter in which position/level i put my bx in.
Really strange is also that when i put it in the lowest value it keeps on being the highst (Front) in the back everything works normally.
When the car stays for a while in the lowest position and i start the car the pump is doing some ticks to get the front in the highest position again. Strange and i have no clue what to do!
Help me!
Front supsension stays at hig level.
mark_l
alan s
- RIP 2010
- x 6
Just out of curiosity, how do the rods look that come from the adjustment lever inside the car? They have clamps fitted to the rods (about 6 or 8mm diameter) at the front that controls the amount of manual adjustment that comes from the manual adjustment to the front & rear height correctors. If one of these has been accidentally loosened & retightened or bent, it could also cause this peoblem. An arm bent at right angles should sit in a slot which at normal ride height, should be 7mm from the front & 5mm from the back of the slot it sits in.
If you can find & check this it may be where the trouble lies. Also, be sure to cycle your suspension from top to bottom a few times & then see where it sits at normal height. I also had a problem with my car when it did the same thing, that it was jammed internally but I won't go looking through the archives for the story on that until this is checked out so as not to confuse things unnecessarily.[:D]
Alan S
Alan S
noltha
