ZX Cuts out when cornering
Paul Patric-white
Unread post by Paul Patric-white »
Does anyone know what would cause my ZX14i to cut out when cornering only to restart when back in a straight line, any help would be appreciated
paulivil
Unread post by paulivil »
<font face='Georgia'>Sounds familiar. If your car is fitted with a distributor then it may be the vacuum operated advance regulator that is faulty. Renewing that part helped when my car suffered from exactly the same you describe.</font id='Georgia'>
Edited by - paulivil on 17 Aug 2001 08:00:37
Paul Patric-white
Thanks for the reply but the part you mention is it part of the distributor.
paulivil
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Yes, but it can be replaced independently. Just follow a vacuum pipe coming from the inlet manifold and see if there is a something that looks like a diaphragm casing at the other end. There may be a solenoid fitted in-line somewhere.
Paul Patric-white
Thanks Paulivil after examining the vacuum advance/retard unit it is faulty due to a broken diaphram, once again Thanks....
