speedo
sijrayner
speedo
Unread post by sijrayner »
hi guys, just in case anyone knows this stuff. speedo on my 2.2Hdi is broken, i imagine i have a common problem which is the tiny plastic knob inside the little electric motor has broken off, i tried to fix it by inserting a cut down piece of metal but it is obviously not precise enough to get the cogs to turn correctly. on a certain website a guy is selling the clocks from a 2.0 vtr and i wondered, the clocks look the same as mine but even if they do not fit, will the little key hole shaped motors be a direct swap. the part number on the ones for sale is PART NUMBER :- 96 352 898 80
why oh why did i buy a C5.
sijrayner
just in case this helps anyone, i fixed my speedo by buying a set of clocks from a 2.0 manual c5 and robbing the small motors from the inside, they just push fit straight in and then replace clocks and it all works fine. anyone with similar problem, i would suggest buying any citroen/peugeot clocks from a scrappy as they all seem to have these motors in them.
