What would you choose and why - a 99 Xantia 1.9TD SX, or a 99 406 1.9TD GLX/Executive/ 2.0 Turbo Executive?
Xantia or 406?
Fox
Xantia or 406?
As I've posted previously I'm looking to change my Xantia in a while. I really like the look of the 406, and several times now I've decided a 406 Executive will be my next car. However every time I then see another Xantia, or get in my own, the doubt sets in and I start thinking that I really ought to get another
franciscolunn
Alex Sh
Fox
mbunting
algieuk
Fox
algieuk
Fox
alexx
I've test driven several Xantias and one P406, mostly 1.8 16V. My choice is definitively Xantia MkII (non-HA). I found ride comfort in Xantia better on all surfaces, while handling was only marginally worse (well, it's not very important to me either). Also, I didn't like 406 brakes - you need to step on the pedal with whole weight to activate ABS. Build quality and other things are similar.
jeremy
Part of it must be whether you regard the technology of the Xantia as worthwhile or not. As you will have seen from a recent posting even AlanS thought that perhaps the time had come for a change but quickly thought better of it!
For my part I purchased my BX TD Estate very cheaply about 3 1/2 years ago as I was bored with my Renault 21 and it needed loads of minor repairs. I well remember sitting in the pub with my wife having a long discusion along the lines of 'what have I done now' and coming to the conclusion that it wasn't that much money anyway if it didn't work! (In fact I couldn't get it over 35 on a test drive - turned out the throttle pedal had broken!)
Since then I have had the fun of learning all about the hydraulic system, my first encounter with ABS systems and have now beaten the thing into submission and its working very well (today at any rate!) My question now is that if it continues to go like this is will I get bored with it and long for another challenge.
For my part if I do replace it it will probably look for a Xantia estate but would not go for a 1.9TD as they seem slower than the BX. I've seen good reports of the 2.1 TD and the HDI 110 seems interesting. Some of the more extreme ones seem interesting but they are all petrol and I don't like paying for fuel these days.
For my part I like the suspension and feel that when its working properly it offers real advantages over a conventional steel setup. What I really like are the fully powered all disc brakes and their loss might put me off a C5.
I keep getting asked when I'm going to change it - and I always say whats the point - (Its probably done twice the mileage of the cars belonging to those who ask). My priorities are that it should be reliable, safe and comfortable and pleasant to drive and it keeps me amused as well (well its better than doing the kitchen isn't it!)
Well if its going to go nicely for a bit I'll be able to get on with my 16 valve! - What about one of those for you Fox - I don't know what the insurance would be like for you but presumably you have a bit of bonus now - hours of fun with one of them! - and probably sufficiently extreme that you wouldn't feel the urge to change it!
Jeremy
Jeremy
Homer
- x 16
I have a Xantia 2.0 turbo Exclusive Estate and I wouldn't swap it for anything. In fact I'm going to have a hard time finding a replacement when the time comes. There doesn't seem to be much around with the same combination of space, power and equipment and a manual 'box.
I've seen lots of complaints about the hydractive ride but it's softer than the BX19TZI I had and though it is a little harder than my prexious Xantia SX it more than makes up for it with the grin it put's on your face when the Hydractive and turbo kick in.
