hi,
car citroen c3 starts but running on three, loads of smoke, got the guy out with is pc, told me it was injector, had all four reconditioned, still same runs on three loads of smoke, can anyone help?
citroen c3 1400 hdi 16v smoke ""help""
SHIGGI42
cheers shiggi42
Citroenmad
- x 110
There is quite a lengthy thread on here about the 16v 1.4HDi C3s and running rough. Ill try and find it.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Citroenmad
- x 110
http://www.frenchcarforum.co.uk/forum/v ... =injectors
Some to try there.
Some to try there.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
JamesQB
- x 5
Is it hard to start?
Were the injectors reconditioned or overhauled? The difference being that overhaul includes changing the control valve and nozzle, testing flow characteristics and re-assigning a new C2i code.
What was used to diagnose the injectors and what was it that pointed to them being the trouble?
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
SHIGGI42
c3 thanks for reply
one injectors was new and re coded in, his dianostic pc pointed to no1 injector water pump side fitted all injectors had them recoded in still same, runs on three with alot of blue/white smoke when revving will not go over 2000 revs seems to run on all four though, but still alot of smoke, dianostic guy saying he thinks engine piston damage
cheers shiggi42
- x 1053
Re: c3 thanks for reply
Number 1 is the gearbox end on this engine so the ijectors could be coded wrong.SHIGGI42 wrote:one injectors was new and re coded in, his dianostic pc pointed to no1 injector water pump side fitted all injectors had them recoded in still same,
