C5 - seatbelts not recoiling properly - MOT fail?
oxtailsoup
Just prepping my C5 2002 model for an MOT later this month.
My seatbelts feel a bit baggy - they don't seem to want to recoil like they should do. Sometimes they do recoil slightly better but I'm wondering if this would be an MOT fail?
I suppose next question is is this an easy fix? Do the mouldings come away easily enough to gain access to the mechanism?
Thanks!
Thanks!
JohnD
- x 72
- x 8393
cachaciero
- x 9
Hmm.... Seat belts and MOT's led me down a somewhat murky thought trail.
I quote:-
"Pyrotechnic systems must be replaced after operating or after ten years from the date of first registration. This must be performed exclusively by the network.
Due to current safety regulations, all operations and checks must be
performed exclusively by the network. All operations which are not carried out in strict compliance with the provisions may lead to the systems malfunctioning or to accidental triggering which may lead to bodily injuries."
Pyrotechnics are used in the seat belt pre-tensioner, question is how long before the MOT tester demands proof that the pyrotechnics have been changed on a +10 year old car.
cachaciero
I quote:-
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5672
Re: C5 - seatbelts not recoiling properly - MOT fail?
I sprayed mine with a silicon cabin cleaner - pull out as much as possible and spray the bit that is normally enclosed. Works for about six months. Best to clean them first so you don't just creat a load of siliconised gunk.oxtailsoup wrote:Just prepping my C5 2002 model for an MOT later this month.
Thanks!
- x 1052
Airbags & the pyrotechnic part of the seatbels are not part of an MOT so there would be no need to see this proof. You cant even fail a pre tensioner if its been deployed as long as the mechanical part of the seatbelt operates properly & the webbing is ok.cachaciero wrote: Pyrotechnics are used in the seat belt pre-tensioner, question is how long before the MOT tester demands proof that the pyrotechnics have been changed on a +10 year old car.
- x 8393
At the moment that iswheeler wrote:Airbags & the pyrotechnic part of the seatbels are not part of an MOT so there would be no need to see this proof.
I'd not be surprised if it were introduced, along with a whole raft of other "enticements" in the not too distant...
Citroenmad
- x 110
Yep ive had this with my C5, (infact in running out of things which have not yet gone wrong, fell off or broken) i just cleaned mine and they seemed to work much better.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Julz
I had a similar problem on my old Passat on the rear belts. The plastic housing where they emerged has become distorted and cased them not to run freely, might be worth checking it's not something similar.
On a similar note, the little plastic buttons that stop the buckle falling to the floor. I've lost a couple of mine, is it possible to get replacements anywhere?
cachaciero
- x 9
Have to say I have wondered about acquiring a set of front belts from an XM including the Buckles the wire mounting on the C5 being to short.
Release the XM belt and it was retracted even before you got the door open I'm fed up up with tripping over the C5 belt or getting it trapped in the door.
Any known "gotchers" doing this?
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
den169
cachaciero
- x 9
JimCitroJim wrote:At the moment that iswheeler wrote:Airbags & the pyrotechnic part of the seatbels are not part of an MOT so there would be no need to see this proof.I think what you're getting at here Cachaciero is when it is made part of the MOT as a further "incentive" to get cars over ten years old off the roads.
Absolutely right on. I mean imagine pyrotechnic devices ,explosives, are they even obtainable from the dealer network by mere mortals? and I bet Citroen would charge mega bucks for changing them on all the airbags seat belts etc. The pressures for doing something like that must be extremely high. Better shut up before the idea gets out
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Julz
jimleshed
When my C5 was first MOT'd when I got it, the only thing that was iffy was the seatbelts - but the friendly MOT man (who I always go to) kindly sprayed them with silicone spray stuff, that seemed to work.
Note to me - Remember to charge battery, bike going for MOT Saturday!
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
oxtailsoup
