ZX clutch adjustment
the_weaver
Unread post by the_weaver »
Hi folks
According to the Haynes manual the clutch on the ZX should be adjusted to give 140 mm of travel from the pedal up to the pedal down position. Is this still a valid method (and measurement) for a very old clutch (> 200,000 miles)?
If the clutch doesn't disengage fully when the pedal is pressed down all the way to the floor should I adjust the cable so that the pedal comes up higher (more travel)? Am I right in thinking that shortening the cable will increase the pedal travel?
Is the clutch pedal normally higher than the brake pedal on a ZX, or level with it?
Paul
x 94
Unread post by citronut »
i think as the clutch wears you need to adjust the pedel up higher than you would expect it to be,
so all you can do is adjust it till you can engage gears smoothly, or as smoothly as possible,
then you know when the clutch is cream crackerd as you cant get your foot between the pedel and steering consoul
regards malcolm
handyman
Unread post by handyman »
Nice one, Malc! :D
Always wonder how to tell when is was time to change a clutch, save for that 'orrible burning smell. :shock:
H
the_weaver
Thanks for the info Malcolm. That agrees with my observations.
Paul
