starting problem TD xantia
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
all, a quick recap..
My xantia has all the symptoms of a flat battery and fails to start from hot or cold. The engine turns sluggishly or fails to turn at all
A jump lead placed between the - battery terminal and a metal part of the engine is all it needs, its perfect then. (with ignition on, glow plugs etc , there are sparks when this spare Earth is connected)
So far I have ..
replaced the main earth cable from battery to gearbox with a spare.. cleaned all contact points until shiny.
changed the starter motor
nothing different.. still a non starter..
any thoughts? should be an easy fix really... John
spider
x 77
Unread post by spider »
So, if you use a jump cable between the negative terminal on the battery and the gearbox its ok ?
It does still point towards your earthing then. You say you have done the gearbox to battery earth lead. It might be worth if possible trying another point on the gearbox with the earth lead, there are a few other nearby bolts you could use.
Check your gearbox (or battery) to body / shell earth too.
Andy.
jimleshed
Unread post by jimleshed »
And why not just add another permanent earth lead directly to the engine, if that is what solves it. Its a fix and it wont do any harm!
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
jgra1
(Donor 2021)
x 37
thanks both..
have replaced gearbox to chassis earth (its part of the main earth cable, but a smaller gauge fly-lead)
Jim, yep think I will just do this now... cant spend much more time on it
