Welding a multiplexed car....
x 1439
:evil:
Not impressed....spotted some peeling paint /dark spot on the NS sill of the Picasso (this is a 2003 car, just 7 years old). Was thinking it would just be peeling a bit as my old Xantia did, but no, it's rusted through :shock: A quick poke made a small hole, but thumb pressure reveals an area about 6" round that is distinctly crusty. So patch is going to be needed I guess - won't pass an MOT like that! No damage apparent, and it appears to be rusting from the inside out. To hide it properly will be expensive -it's a painted sill, not an undersealed one. So, probably just DIY, grind the welds flat, and blow it over with a rattle can :P Then chop it in.... 8-)
Anyway, any experience of MIGing multilplexed cars? Just drop the battery off, following the normal procedure, and away you go?
Citroenmad
x 110
Unread post by Citroenmad »
Sounds as if there might be a bunged up drain hole somewhere?
Ive had this before on a car, the drain was bunged (with the missing cap from the washer bottle top) and over time it caused the sill to rot out.
Ive never seen a rusty Picasso, cant imagine its normal.
No idea about welding a plexed car though, i asume its just as normal.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 94
Unread post by citronut »
cant you just bung a surge protector across the battery, like i do whilst weldding other cars, they dont cost a lot of dosh and dont have a lot inside of them,
im sure Jim will sudgest what component/s to use instead
regards malcolm
handyman
Unread post by handyman »
Hi Richard, I would suggest not only disconnecting the battery, but also the connector plug to the alternator and all the ECUs as they will all suffer if there is a surge or spike that runs to earth in the car.
I know its a pain, but I always disconnect any sensitive electronic units in a car before commencing any electric welding. It only takes a few milli-amps and the component is toast. A nasty shock then follows when you find out the cost of the replacement parts. :shock:
Handyman
Clogzz
x 40
Unread post by Clogzz »
Was thinking of earthing the positive battery lead.
2002 C5 2.0i AL4 239,000 km 76372389
x 1044
Unread post by wheeler »
Doesent it have a 12 year anti corrosion warranty for corrosion from the inside out ??
x 1439
wheeler wrote:Doesent it have a 12 year anti corrosion warranty for corrosion from the inside out ??
Well, probably, but I've no idea when it was last near a dealer for an inspection, so I doubt it's valid - no harm in phoning them up to ask I suppose :lol:
x 1439
Looks like it should have had an inspection last year at 6 years old, which it certainly didn't. Will be to my account then :cry:
Still I managed to re-fix the exhaust heat shield yesterday which has stopped it rattling like a demented cement mixer every time you reversed it :lol:
BTW - Citroen are still knocking Xsara Picassos out new - only 2 models available, 1 Derv, 1 petrol. The Derv one (Hdi 90, VTX+ or somthing) has a list price of nearly TWENTY GRAND!!!! Who are they trying to kid?????
