Help! I have a Citroen Xantia, 2.0 Hdi, Estate, 1999, which i adore, but have just had my first bit of engine trouble.
At 2900 revs the Turbo seems to Flat-line. Main dealer say it is the ECU. The turbo control switch failed and this seems to haev started the problem, but even after this was replaced it nopw errors.
The Main dealer say they reset the ECU to basic settings, but still not fixed.
Any ideas?
They have quoted £700 for the ECU replacement.....
Thanks,
matt
Turbo fails at 2900 revs, main d say it is ECU, Xantia
zoics99
I love my Xantia!
DHallworth
- x 163
If it is the ECU, that's about the going rate from a main agent or it was in 2001 so by todays standards, probably isn't a bad price.
My dad paid £700 for an ECU to be supplied and fitted to his Activa back in 2001, 2 months after the warranty on the car had expired.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
spider
- x 77
Gammy leg
ECU's can be repaired/refurbed ( although not all of them ). These people http://www.bba-reman.com/uk/index.aspx should be able to quote for a replacement if you find that it is necessary.
Their forum is quite good also - although not as good as FCF of course.
Gammy
Gammy
zoics99
MikeT
- x 232
cachaciero
- x 9
Don't know anything about Xantia's but........
If the turbo is flat lining then that would likely be because the waste gate is opening and holding it down to that speed or more accurately pressure. I guess that the ECU will control the waste gate electro valve to apply vacuum to the waste gate but not sure which way round probably vac to open waste gate.
The ECU in turn is almost certainly looking at manifold pressure for primary control.
So A Lexia run looking at waste gate control signal and manifold pressure might be a good start plus checks of the vacuum supply to the waste gate might show something.
Removing the vac supply to the electro valve and then going for a run might prove something as well don't forget to plug the open vac pipe.
Of course this could be complete b*?&ocks as like I said I know nothing about Xantias.
Edit
Just thought some more about this how do you know the turbo is running out of boost? could just as easily be running out of fuel the effect would be the same.
cachaciero
Edit
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
- x 9
Further to my previous commenst FWIW 2900 RPM sounds awfully like the LIMP MODE limit on a C5 would expect an error code to be locked into the ECU + engine management light though.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
zoics99
zoics99
Citroen have returned my Xantia, and recommended taking it elsewhere for the ECU to be checked.
First they changed the electro valve, and then they thought that the Cat was blocked, but this did not seem to be the case. They have put the original Electro valve back on, and have only charged £50 for the diagnostics and labour, so not too bad really.
So now I will do a little trouble shooting before I take it in. It appears that the the car goes into Limp mode when under load. It was revving freely until I accelerated up a hill, at which point the limp mode cut back in. It certainly seems to lack a little power throughout the range, even when not in Limp.
I love my Xantia!
MikeT
- x 232
cachaciero
- x 9
Yes I would second that, very strange where did the main dealer suggest you go? to a Citroen agentMikeT wrote:I'm surprised that a main dealer suggests you go elsewhere to get the standard ECU diagnosed! What's the reason there?
Did they give you a diagnostic printout? If not, can you go back and ask for it? I suspect it would be most helpful and revealing.
I suspect it's a case of "Ah.. it's an old Xantia we don't fix those on principal"
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
zoics99
apparently they spent quite some time on it, and they outsource all their older ECU items. I think they were keen to get rid of it as they could not fix it, and I guess it is cheaper this way for me...
Will be unable to look at the car for a couple of days, will be back when I have more info. Thanks all.
I love my Xantia!
zoics99
update - still not working
Hi all,
I have cleaned the MAF sensor now (with meths and cotton buds), just after the air filter. This has made no difference, and I am looking to the MAP sensor? Is it near the intercooler, as I am yet to find it.
The pipework seems OK. What is the best access to the EGR valve and associated pipe work for the vacumn feed?
Thanks,
Matt
Thanks,
Matt
I love my Xantia!
MikeT
- x 232
