c5 brake light flashing on dash
mrlogik
hi all my c5 2001 hdi 110 has some sort of braking error as the little red brake circle on the right is flashing on and is beeping at me,wasnt to bad at first but its got progressively worse and i must get it sorted. It has plenty of brake fluid,handbrake is releasing ok, and the brakes work fine so would it be an abs sensor or low pads?
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
h2ocooler
Guessing its low pads, does it do it more when braking or all the time?
Rob
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
JohnD
- x 72
Julz
I had a similiar problem on a Metro once, where rust had formed on the edge of the disk making the edge of the disk protrude further, this had cut through the sensor wires and caused the dash light to flicker.JohnD wrote:Maybe the covering on the pad wires has rubbed through and is shorting out intermittently.
coolscan
