Picasso Ignition Switch
x 5672
A friend at work has a Y-reg Picasso. There is a fault with the electrikery* bit of the ignition lock.
(*technical term)
He had the aerial replaced a while back as the car wouldn't start - wouldn't release the immobiliser, but now his air conditioning won't work.
A friend in Poland had taken it off and cleaned/re-bent the contacts and it worked for a while but has failed again.
Can anyone come up with the proper name of the part and a part number/price for it please and would it be available from anywhere other than the dealer?
Info from car ID plate on the clickity-pic:
spider
x 77
Unread post by spider »
I'd have to assume its going to be main dealer only for this, unfortunately.
I could be wrong (perhaps the later vehicles are separate) but the older ones, the whole ignition barrel, well the innards of it anyway come complete.
I mean you get the lock mechanism with the actual ignition switch on the end of it already, its not really meant to be taken off separately, but as I say they might have changed this, certainly the earlier vehicles its all-in-one, complete with a few inches of wire ending in a plug or two.
Andy.
x 1052
Unread post by wheeler »
It's the ignition switch thats faulty. On the picasso it can be bought seperately from the whole lock assembly. Part no 992712 & it's about £70. Nothing will need to be re-coded.
x 5672
Thanks wheeler, just the ticket :)
meexi
Unread post by meexi »
wheelers correct, fairly easy to fit just take your time and remember the route of the cable
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
