206 Clutch Swap & Gearbox/Differential Rattle??
Gammy leg
Unread post by Gammy leg »
Can anyone provide a link to an online repair manual for a Pug 206, specifically the section for changing a clutch?. Never done a Pug before let alone a 206.
Anything will do, even a copy of Haynes :D
EDIT: I've changed the subject title of this thread to more accurately reflect the bulk of the subject matter contained herein.
Gammy
Citroenmad
x 110
Unread post by Citroenmad »
http://cgi.ebay.co.uk/Peugeot-206-Hayne ... 3eff36c563
Quite a few haynes manuals for the 206 on ebay.
What engine/year is yours?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 8447
As far as I know, the 206 BoL only covers the early models. Luckily Robyn'sd is a n early one. I don't think it quite gets to 51 platers so beware.
That's the pale blue cover one...
spider
x 77
Unread post by spider »
Funnily enough I was in Halfords a few days ago trying to buy some Hylomar (they did not sell it anymore, but that did not surprise me) I called in simply as I was going past, anyway they had two 206 manuals as I had a wander around and actually wanted to look at one.
One up to about 2000 ('X' Plate) and one after that.
I'd assume the later ones cover the changes to the system (aka: multiplexed as from 2000 on they were) , the 1.4HDI and other 'new' engines.
So there are definitely two about, rather than one that covers them all.
Andy.
x 94
Unread post by citronut »
if its a 1.4 they are very easy, i'd even say self explanatry, and fare easyer than a XANT,
regards malcolm
spider
x 77
citronut wrote:if its a 1.4 they are very easy, i'd even say self explanatry, and fare easyer than a XANT,
regards malcolm
Off topic: Have you had the 'failure to start' problem with the 1.4 HDi caused by the plastic fuel pipes across the back taking air in ? , I know there was a 'batch' (well, more or less) that had this problem. Effected some Ford's too as they shared that power unit.
Andy.
Gammy leg
Thanks chaps,
It's a 1.4, 8v petrol 2003. I'm struggling to remember the last clutch that I replaced. I have a feeling that it was a R18 back in the day of in-line gearboxes. From memory I don't recall ever having done a transverse although I'm sure that I changed my BX14 clutch at some point.
Thanks for your help. If I get stuck I'll ask.
Gammy
spider
x 77
I vaguely remember doing one on a DW8 206, I did have a problem with it but that was due to the hydraulics rather than anything else. Cannot recall what the problem was to be honest it was a long time ago. :)
Yours will probably be cable anyway I'd expect, won't be difficult anyway I think, small TU engine and gearbox.
Remember to replace driveshaft oil seals to avoid future leaks, they do not like being re-used, you might get away with it but its worth changing them to be honest as you will have to pull the driveshafts out.
I don't anticipate any other problems, possibly the pinchbolts for the bottom ball joints might break if you are unlucky undoing them, but that's about it really.
Andy.
x 8447
Gammy,
I'd say a clutch on an 8V TU would be a walk in the park. I've done one on a Paxo and it really was so easy (compared to what I normally work on!!!) and would agree with Andy on the lower swivels. They can be a *(^*( to get apart due to angles...
I'll have a 206 clutch to do sooner or later once Robyn has finished learning on hers!!!
x 94
Jim wrote
"compared to what I normally work on!!!"
yep them there clutch plate's presure plare's and thrust bearings on those V6 houcamatics, are real BBBBB TEA HE
regards malcolm
Gammy leg
Dim question, but it's been a long time. Do I need to drain the gearbox prior to removal, ie will it leak everywhere when I remove the driveshafts?
spider
x 77
It will pour out when you pull a driveshaft out :)
I'd advise draining it first, otherwise you will make a nice mess (as it won't come out the diff housing 'nicely') , plus when you tip the box a bit when its out, more will pour out anyway.
Actually, you will still get a bit of residual oil anyway even if you drain it (watch that if you tip the box over)
Andy.
x 94
i never drain the box first, i just place a large tray underneath and pop the shafts out,
but it is probably best to drain first then it will gat a full oil change at the same time
regards malcolm
Gammy leg
Thanks Andy & Malcolm. Just picked up new National clutch from Ajays, would have liked a Valeo but current shortage of paid work means that I had to go for the economy option. :)
Gammy
x 94
a customer of mine supplied his own clutch a few years ago, guess what it was a National kit, once fitted to his BX i had take all the adjustment up to the end just to get any clutch at all,
mind you it was a TAXI driver and he never did finnish paying me what he owed,
i did not think GSF charge a huge amount dfor a clutch to fit small engined 206
regards malcolm
