part numbers
xantia sx auto
part numbers
Hi does anyone know the part number for a genuine citreoen accumulator sphere for a w reg mk 2 xantia, please help as i might have one just want to make sure it's correct before fitting!!!
thanks all
thanks all
Pleiades
I cant remember the part number, but if it's a main accumulator, it will be the correct sphere. Should be no damper in the neck and stamped 62- on the top.
All main accumulator spheres are the same, from the DS through to the Xantia, all models all years (except the very early pre 1966 DS with lhs2 fluid)
Regards
Martin.
Regards
Martin.
addo
- Sara Watson's Stalker
- x 95
From "Xantia World" website, there are three possible part numbers:
96 154 588
95 451 376
95 437 354
Any should suffice in your situation.
Look for a four digit code stamped as well, with a slight space after the first digit. EG: 4 077 This represents the year (first digit) and then the day in that year. So, the number above would likely be 2004, 77th day (1994 would be less likely). Ideally, the date should be within the last year or so, if you are buying "off the shelf". I would also see if anyone local can pressure test a new sphere before fitment.
96 154 588
95 451 376
95 437 354
- x 94
these are for non H/A cars
95 669 124
REGULATOR SPHER
450CM3 75 BARS
- W/O ACTIVE ANTI-ROLL
FRONT
95 669 124
REGULATOR SPHER
450CM3 75 BARS
FRONT
96 045 530
REGULATOR SPHER
400CM3 50 BARS
REAR
these are with H/A
95 669 124
REGULATOR SPHER
450CM3 75 BARS
- INJECTION XU10J4R AND WITH ACTIVE ANTI-ROLL
FRONT
450CM3 75 BARS
- TURBO INJECTION XU10J2TE AND WITH ACTIVE ANTI-ROLL
FRONT
450CM3 75 BARS
- TURBO DIESEL XUD11BTE AND WITH ACTIVE ANTI-ROLL
FRONT
450CM3 75 BARS
- DW10ATED TURBO DIESEL AND WITH ACTIVE ANTI-ROLL
FRONT
5276 09
450CM3 70 BARS
- INJECTION ES9J4 AND WITH ACTIVE ANTI-ROLL
FRONT
5276 06
REGULATOR SPHER
400CM3 55 BARS
- RR SUSP SPHERE UREPAN AND WITH ACTIVE ANTI-ROLL
regards malcolm
95 669 124
REGULATOR SPHER
450CM3 75 BARS
FRONT
95 669 124
REGULATOR SPHER
450CM3 75 BARS
FRONT
96 045 530
REGULATOR SPHER
400CM3 50 BARS
REAR
these are with H/A
95 669 124
REGULATOR SPHER
450CM3 75 BARS
FRONT
450CM3 75 BARS
FRONT
450CM3 75 BARS
FRONT
450CM3 75 BARS
FRONT
5276 09
450CM3 70 BARS
FRONT
5276 06
REGULATOR SPHER
400CM3 55 BARS
regards malcolm
- x 1470
- x 94
yes ok silly me forget i spoke allready,
here is/are the right one/s
95 666 763
SPHERE + GASKET
400CM3 62 BARS
- TALC DESMOPAN ACCUMULATOR SPHERE
5 451 376
400CM3 PRESS 62 BARS
- UREPAN ACCUMULATOR SPHERE
E 587 001
ERP ACCU SPHERE
- TALC DESMOPAN ACCUMULATOR SPHERE AND AGE >= 5
E 587 003
- UREPAN ACCUMULATOR SPHERE AND AGE >= 5
whats this ERP sphere for,
there is also a slim line sphere listted, like the sphere's on a C5
regards malcolm
regards malcolm
95 666 763
SPHERE + GASKET
400CM3 62 BARS
5 451 376
E 587 001
ERP ACCU SPHERE
E 587 003
regards malcolm
regards malcolm
xantia sx auto
the one i have is a 95 666 763 so that is ok???
it was described as a circuit breaker sphere which i presume is another name for it???
thanks
p.s is the anti sink sphere supposed to have a pipe going into it as mine has not!??? i had a look yesterday just thinking about doing that one too but heard it had a 9mm pipe nut thing you have to undo but can't see it!
accumulator is needed more though so if someone can confirm this part number is ok then i'll crack on
thanks all
thanks
thanks all
xantia sx auto
xantia sx auto
- x 94
xantia sx auto wrote
"doesn't seem to have anything in the neck but it closes to a small hole about and inch down"
that is definatly an acumalater/circuit breaker sphere, as it dose not have a bafle disc in the end,
the anti sink sphere, the one on the rear axle anyhow, is screwed to a bracket the has a pipe screws staight into it with a 9mm pipe nut,
i usualy crack the sphere thread then hold the pipe nut with a spanner or grips, then unscrew the sphere,
regards malcolm
regards malcolm
xantia sx auto
Today has been an eventful day!
I have broken 2 filter wrenches, and the darn thing has not moved a mm!!!
think i'll be looking for a chain wrench tomorrow or some nut bar to make the special tool!!
can't believe how tight it is, got a feeling this sphere has never been done as it is genuine and looks like it's been there a long time! all i managed to do was knock a bit of paint off!!!
hopefully i'll get the darn thing off tomorro!!!
addo
- x 95
- x 94
we just recived a catalouge from TOOL STATION,
there is a pipe chain wrench which looks a bit like my old STANLEY 30cm wrench, which has never let me down,
go to there link below and enter in there search box 56261
http://www.toolstation.com/shop/Hand+Tools/d10
i use my one with a two foot tube on the slid over the handle, and i have owned it for quite some years
regards malcolm
regards malcolm
addo
- x 95
- x 8422
Sometimes, even a sphere tool will fail. I had this on eight out of the ten spheres on my Activa Project.
Then it's time to get serious and arm yourself with a club hammer, a cold chisel and a big punch.
Raise a ridge on the welded seam of the sphere using the cold chisel and club hammer and then, as soon as enough ridge has been raised, use the club hammer and punch to deliver some dead blows to the sphere. This will remove the tightest of the tight...
It seem brutal and dangerous but is perfectly safe to do.
The cause of all this tightness is not the threads but corrosion and muck on the rubber sealing ring. The rubber ring sort of glues itself on over time.
You may find the old sphere is ruptured and full to the brim with LHM.
Replace a sphere only hand-tight and fit the new seal to its groove in the sphere block first before screwing the sphere home. Make sure you don't disturb the seal as you start the new sphere in the threads and then end up nipping the seal.
