Glow Plug Replacement advice
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi All
May seem a strange question but i need to change the glow plugs on my 2.1td. Now i have the replacements but as ive never had to change any before im a little unsure as to the best procedure :oops:
Having read of stories of the plug taking the thread with it etc is it best to do them with a warm or cold engine,do you put grease/copperslip on the new ones :?
Any thoughts much appreciated :)
Cheers
Colin
x 8386
Hi Colin,
2.1TD specifically, remove the top half of the inlet manifold for ease of access.
Replace the leakoffs whilst you're there as a precaution.
I'd do the glowplugs on a warm engine after dousing their threads in Plus-Gas.
Use a good quality 12mm offset (cranked) ring spanner to undo them. Have a good long one so you can apply steady high torque to it.
Go carefully and there should be no nasties awaiting... Don't jerk at a tight glowplug, just apply steady concerted pressure. It's jerking on a short spanner that breaks things.
Stuff rag down behind the pump to catch any potential escapees.
admiral51
(Donor 2026)
x 391
Thanks Jim :)
Have become a dab hand at removing the top half of the inlet manifold :wink: ive done the leakoffs and also replaced the fuel line and both times the manifold cover was removed :lol:
Not a good idea to use a deep 12mm socket then :roll:
Pm sent on an unrelated matter :)
Colin
