Oil Change
zach
Oil Change
Unread post by zach »
Hi all,
Bit of a problem with the oil in my 1995 zx 1.4 8v. Recently, whilst going round corners my oil light was coming on. After a quick check under the filler cap, i started to wonder if the poor car had ever had an oil change, the oil was generally quite dirty and lumpy.
Went and bought some oil and a new filter, but i dont have a big enough socket for the sump plug (21mm wont fit).
Would anyone know the size of socket needed to remove the plug so i can head down to halfrauds tomorrow to get one.
Cheers
x 8063
Surprised a 21mm won't fit Zach :? That's the normal size...
Maybe a strange after-market one has been fitted.
Best go to Halfrauds and ask if you can try a selection...
Xantidote
x 5
Unread post by Xantidote »
If you measure across from one flat of the sump plug to the opposite flat, using a metric ruler/tape measure, you should get very good idea of what size you need. With luck you'll be spot on :)
Martin
1995 Xantia TDLX (deceased :( )
spider
x 77
Unread post by spider »
EDIT... I just re-read your post, sorry you said 1.4, so TU.
You need a 24mm for these. :)
You will be pleased to learn the sump washer is re-usable a few times if its the correct one (metal with a rubber insert)
Andy.
zach
Xantidote wrote:If you measure across from one flat of the sump plug to the opposite flat, using a metric ruler/tape measure, you should get very good idea of what size you need. With luck you'll be spot on :)
All right, funny guy :P It saves me the bother of going out an checking it tomorrow morning, excuse my laziness :)
24mm, cheers mate!
