Hi all,
I have searched this fault and found topics, but not managed to find a cause or remedy.
My O/S indicators stay on occasionally, not flashing just on constantly. I have read that it maybe the alarm ECU or the hazard switch that might be the culprit.
I take the bulbs out so as not to drain the battery (apart from the dash bulb. LOL.) and the fault corrects itself when I next look. There doesn't seem to be a trigger, it sometimes happens when I'm driving, when I unlock the car with remote or when it's parked.
It doesn't set off the alarm.
Has anyone had this fault? If so, did you find the cause?
Indicator problem
Indicator problem
95 Xantia 1.9TD SX - Now sold
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
I can tell you 306's used to do this, (typically the offside indicators use to just stay on not flashing just 'on')
The cause was 99% of the time the alarm ECU which on a 306 fitted under the drivers seat (seat out / lift carpet for access)
Although where it would be on your Xantia I am not sure.
Hope that's a little bit of help if nothing else anyway.
Andy.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Yup It IS the Alarm ECU in Xantias aswell...
The unit - its located under the PASSENGER seat, under the carpet!!
So seat out, edge of carpet up...
Ive had two cars do this now..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Martin,
Was that the I supplied you???
If so, I shall send another FOC to you!.. All of them from 1993 to 1997 are the same format and do the same job...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
