Seat Belt light coming on and off
boristhespie
x 4
Unread post by boristhespie »
The C5 seat bely light keeps flashin on and off. It's as irritating as hell. I assume it's a lose connection which is at the belt engagement end. HOw can a layman remedy this? Thought about cutting wire.
C'est pas possible!
boristhespie
x 4
no takers?
C'est pas possible!
h2ocooler
Unread post by h2ocooler »
Well im guessing there is a switch in the seatbelt catch unit, you could have a look to see if it will come apart and check that the switch is working.
Either that or just bypass the switch, DONT FORGET TO PUT YOUR BELT ON IF YOU DO BYPASS IT.
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
Gingerposer
x 6
Unread post by Gingerposer »
Is there any grease/dirt on the metal clip which might be affecting a contact? You could also try spraying an electrical contact cleaner into the catch unit. Other than that I have no suggestions
x 1459
Unread post by xantia_v6 »
Does it still do it if there is a (belted) passenger? It could be a problem with the sensor in the passenger seat.
