C5 electric windows
Julz
C5 electric windows
I notice the window switches have 2 positions on the raise /lower, to either go partly up/down or all the way. On mine though the raise fully function doesn't seem to work on both front windows. Should LX's have this functionality or is this a fault? is it likely to be a switch problem or is there some way to set home positions?
- x 5674
boristhespie
- x 4
mrlogik
switch filth
If you pull the switch apart and clean where the little rubber pads make contact they will work a lot better as mine stopped working altogether one wet winters evening,a bit of carb cleaner and a rag has cured the problem and theyve been fine for months now.
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
