hi just come across this site and found it very informative must congratulate you lot on something useful on the web.
my problem is a few weeks ago i bought a xantia estate p reg 1.9 td
an to be honest am very surprised at how nippy it is. how ever there are a few things i would like to sort out.
suspension , the front of the car is a lot higher than the rear in normal mode,to the point of the sill of the car not being level with the ground.
in the high mode both front an rear go up higher an in low mode both go right down.
i have topped up lhm , am i right in assuming the dog bone connectors on the height correctors are ok because the car goes up an down when put it in these modes?
would it be some adjustment of them some where wrong or need reseting or is it something i've overlooked?
any help will the Greatly appreciated
thanks kev
xantia suspension help needed
Citroenmad
- x 110
Sounds like a sticking height corrector. Its often the rear which sticks, though yours sounds like the front. Is the front too high or the back too low?
Does it ride softly? I would expect the end at the wrong height to be pretty crashy.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
Two or three applications of WD40 on the height corrector linkage over a couple of days should free them off. Look along the anti roll bar and you will see a clamp round it, follow the 'U' shaped rod and you will find the valve on the other end. Dont get under the car unless securly jacked or on a ramp - there heavy
Xaccers
- x 188
Once free, spray them with a liberal coating of grease such as lithium spray grease
DIY sphere tool
DIY sphere tool
keving
- x 8385
Yes, the lever does work on the height corrector Kevin, but on a different and independent part of the mechanism.keving wrote: does the slider between the seats not work the height correctors? because it goes up and down when thats operated.
The part that is operated by the white link from the anti-roll bar can be totally seized whilst the part operated by the lever will still work and behave normally.
This drawing may help make it clearer...
Only one way to test height correctors and that's to use your own weight. Sit on the boot lip and feel the car go down and then correct back to normal height after about 20s. get out, feel it go up high as the weight is relieved and then fall back down to normal height.
Although not quite so dramatic, the front should behave exactly the same if you sit on the slam panel and make the front go down it'll correct itself back up again just like the rear does.
If these tests don't pass, the fault lies in the height corrector mechanisms. The hydraulic part very rarely fails but any stiff ness in the mechanism will really upset the operation of it. Note that very small movements on the hydraulic valve makes a big ride height difference and as a result, the whole assembly is sensitive.
XantiaDaveEire
- x 4
- x 8385
They're very shy, retiring creatures Dave.XantiaDaveEire wrote:where abouts is the front height corrector located
They live in the middle of the rear part of the front subframe, well beyond the steering rack and well hidden. Follow the rod from the height lever...
You'll only see its mount at first glance. Needless to say they are somewhat of an adventure to remove/replace...
XantiaDaveEire
- x 4
