Offside rear tyre wearing down fast
cox377
Unread post by cox377 »
Hello Guys
I've noticed that the offside rear tyre is wearing down a on the outer rim. This is second tyre I've put on in about 2 months. I know I drive swiftly but it's getting silly.
there looks to be scrapping on the actual tyre.. loads of little slices in the rubber.
Can I assume this is a worn bush or something?
CoXne
Citroenmad
x 110
Unread post by Citroenmad »
What car is this on?
Could it be catching something in the wheel arch as the wheels is moving over bumps?
Have you had a 4 wheel alignment check?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1487
Previous posts would suggest it's a Xantia. In which case, most likely to be the trailing arm bearings at fault - the tyre is probably rubbing on the inner wing, hence the damage to it.
