Xantia Fuel Filter Housing 2.1/1.9TD
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi all
Can anyone confirm that the filter housing top is the same size even though the height of the housing is different.
The reason im asking is i have a slight crack(broken off :twisted: ) in the outlet pipe on the lid on my 2.1TD and im hopeing to aquire a lid from a 1.9TD today :)
Cheers
Colin
Old-Guy
x 24
Unread post by Old-Guy »
Can't confirm that they are the same. However, when I cracked mine (changing the cold idle thermostat) on a Saturday afternoon, I repaired it very successfully (still in use after 2 years) with Araldite having very thoroughly degreased the cover with hot Fairy (powder) and then with IPA (isopropanol not India Pale Ale!).
Guy
spider
x 77
Unread post by spider »
I'm about 90% sure they are the same, sorry I cannot be 100%.
The filters are similar between sizes anyway (only length) so I would be surprised if the lid was different...
I don't think the 'lid' is available separately otherwise I could check...
Andy.
spider
x 77
Update, I just checked something...
For a 406 (so should be the same, albeit differing part numbers no doubt):
190418 - FILTER COVER (XUD9SD)
190418 - FILTER COVER (XUD11BTE)
So they are the same after all, and available separately if needed. Hope that helps, that's just the 'lid'
Andy.
admiral51
(Donor 2026)
x 391
Thanks for the replies guys :D :D
Have managed to aquire a second hand lid from a donor vehicle and all is now well again :) :)
Must remember not to be quite so aggressive in future costs money in the end :oops:
Colin
