Xantia MK1 dash switch pinouts
MikeT
x 232
Unread post by MikeT »
Does anyone know the pin assignments for the push button dash switches or can point me to where I might find the info as Haynes is no real help?
In particular, I need to know how the illumination works. It looks like there's one feed for light off, one for lights on and the obligatory earth but which pins and what voltage?
x 8409
On a MK1 Mike? Surely yours is a MK2 :? :?
I might be able to provide what you need but be aware that every switch is different. What holds good for one does not hold good for all...
MikeT
x 232
Quite right Jim, if I had a MK1 I could take readings off the harness connections and work it out from there.
The switches I have are Hazard, Air con, Rear screen heater and Rear electric window defeat (or is it internal alarm sensor defeat?)
Is the dash lighting all 12v?
