My 2001 Synergie HDi has just presented with a problem,when I switch off the engine it runs on for a couple of seconds before finally stopping,the engine management light is also on.I have only had the car a couple of weeks so dont really know the history of it.Any ideas on what might be the problem.
Ray
Synergie HDi running on
DickieG
- Monaco's youngest playboy
- x 33
It'll be down to a fuel pressure fault, try cleaning the connection on the fuel rail pressure sensor and the fuel pressure regulator, its also worth removing the pressure regulator to check for any metal swarf collecting on it (the regulator is found on the end of the pump).
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
racingraymond
DickieG
- x 33
If the fault is what I think it may be then I imagine that the ECU will be running in limp home mode (reduced power), you may be able to drive it like this for some time but I can't imagine the fault will improve which may leave you stranded, or if there is evidence of metal swarf on the pressure regulator then potentially fatal damage could be caused to the high pressure pump and injectors (very expensive). A judgement call for yourself really, how long is a piece of string?racingraymond wrote:Is it ok to drive as it is or will I cause damage ?
Thanks for the reply
Checking the connection on the fuel rail can be done within a few minutes, if only by wiggling it you may temporarily solve the problem.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
racingraymond
Thanks,I wont drive it.When you say there maybe a problem with the connection on the fuel rail sensor,do you mean that the wiring connection is not very good then it sends faults to the ecu resulting in the problem ?DickieG wrote:If the fault is what I think it may be then I imagine that the ECU will be running in limp home mode (reduced power), you may be able to drive it like this for some time but I can't imagine the fault will improve which may leave you stranded, or if there is evidence of metal swarf on the pressure regulator then potentially fatal damage could be caused to the high pressure pump and injectors (very expensive). A judgement call for yourself really, how long is a piece of string?racingraymond wrote:Is it ok to drive as it is or will I cause damage ?
DickieG
- x 33
In a word "Yes", ideally remove the connector from the sensor and take a look for corrosion/clean as much as possible then squirt some electric contact cleaner into both ends prior to refitting.racingraymond wrote:When you say there maybe a problem with the connection on the fuel rail sensor,do you mean that the wiring connection is not very good then it sends faults to the ecu resulting in the problem ?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
racingraymond
