Hi everyone.
I have a 2006 206cc 1.6 HDi and have a tracking problem.
The problem is that the o/s/f wheel is wearing prematurely on the outer edge.
I had the tracking done and the car began pulling severely to the left when the steering wheel was straight.
To ease the problem, the tracking was done again and the o/s/f wheel was adjusted outwards by around 2 degrees!
The steering is now ok around the straight ahead but when I let go of the wheel, the car pulls to the left again.
Any advice would be greatly appreciated.
Many thanks - Ben
Steering/Tracking problem
spider
- x 77
Assuming nothing is damaged or bent, my first thought is the wishbone bush'es, as if there's movement in these (sometimes you can see them 'out' of the arm a bit as they are pressed in vertically) you will never get the tracking right.
Get the front wishbone bushes checked, its quite common unfortunately, I used to do loads
Assuming they are OK and the trackrod ends (and rack!) , wheel bearings (rare) are OK, it should track up fine then
Andy.
ayresie
spider
- x 77
