Citroen C5 estate creaking suspension
dmatthews
My 2003 C5 HDI estate makes a loud creaking sound pretty much all the time.
It used to just creak during reversing and then when rolled by hand (using the roof rack) - it was only noticeable from outside of the car.
However for the last two weeks it has now started creaking at all times at any speed, and can be heard from inside.
It has completed 62k miles and had a dealer service a few months - I asked them to investigate but they claimed to not be able to hear it.
Is this a common problem, does anybody have any ideas as to what the problem is please? I've heard it on another C5.
dnsey
- x 19
dmatthews
Dommo
- x 20
dmatthews
JohnD
- x 72
- x 5673
GBiernfels
CREAKING/GROANING REAR SUSPENSION - C5
Hi
I am interested to know whether you replaced the rear bearings on your C5 to achieve the correct camber and whether this has this got rid of the creaking noise from the rear end ?
I have a 2003 2.2HDi Automatic Estate which I bought at 104,000 miles. The car developed a groan @ 144,000 miles which has become progressively louder.
I have had a history of brake squeak(l) and linkage rattles but this distinct groan as opposed to a rattle or squeak(l) is evident: 1) when parked up, with engine off and the handbrake applied or not applied; 2) when lowering the tail-end to hitch on a trailer using the height adjuster button in the boot; 3) when passengers are getting out of the car;
The car has sailed through its MOTs in the 5 years I have owned it. The ride is like a flying carpet, it tows like a train and I am reluctant to sell as it is in A1 condition and valued @ £750 as a trade-in - as the MOT tester said at its last MOT, we can't fail it for an occasional squeak or groan.
My thoughts were that the noise seems to be coming from the rear wheel hubs when these rotate into their final parked position. However, another mechanic suggested it may be originating from behind the aluminium-encased rear axle.
Have any members had similar problems ?
Would just like to identify potential areas for my Citroen garage to investigate.
Many thanks
Graham
Many thanks
Graham
- x 5673
cachaciero
- x 9
There have been several go rounds on this subject at various times as a search will show.
Go have a look here http://www.frenchcarforum.co.uk/forum/v ... ailing+arm
This is a wide ranging (as ever
discussion on the subject.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Citroenmad
- x 110
Our previous C5 estate had to have a rear arm bearing replaced at 105K miles as it was causing a loud cracking noise when going over bumps. There was no extra camber on the rear wheels however.
It can be a thing C5s suffer from with higher mileage, estates seem more prone to them. Probably as they are often used for carrying heavy weights.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
GBiernfels
Dear all
Many thanks for your prompt suggestions.
I have looked at the rear wheels tonight and they do look very upright and parallel but I will definitely ask the mechanic to check out the condition of the trailing arm/bearings.
Presumably if the camber is out , would this show with abnormal tyre wear on the inner tread pattern ?
Thanks again
Graham
Thanks again
Graham
Citroenmad
- x 110
Even with worn trailing arm bearings C5s dont always produce a high rate of camber. So it might not show up in the tyre wear.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
GBiernfels
Many thanks for your advice update.
In terms of the suggested "fix" from several members of fitting grease nipples and regularly flushing grease up into the space between the rear suspension arm bearings, is there a particular specification of grease needed.......possibly lithium-based ?
This seems to be the cheapest "solution" to explore first.
Thanks again.
Graham
Thanks again.
Graham
