Obituary - Xantia 1.9TD
MikeM
Unread post by MikeM »
It is with great sadness that I report the passing on of my beloved Xantia.
She died suddenly from massive heart failure, doing what she loved most, motorway cruising.
RIP (Revivable In Pieces) http://www.frenchcarforum.co.uk/forum/v ... 482#218482
Seriously, I annoyed. and that's being polite. All the work I've put in and all the help from you guys over the last six months. Not to mention the money I've spent. and she goes and shoves a big end through the front of the block.
As we were on the side of the M11 the RAC told us we were a priority but it was still 1hr 15mins before a patrolman phoned to say that he was coming but couldn't help as he can't even tow a Xantia.
When he arrived his inspection took less than three seconds (that really was all that was necessary) before climbing the embankment to join us and apologise that the control centre hadn't just sent a flat-bed recovery truck in the first place. It seems us mere mortals can't be trusted to diagnose a catastrophic engine failure and a patrolman must be sent to confirm or fix (yeah - fix that by the side of the road).
Still, all frustrations and standing in cold winds aside, the guys at the sharp end were fantastic and even though the RAC's procedures may be a nightmare - they did get us home and our policy did only cost 12 quid so money well spent by SWMBO.
If anyone's interested in any of her organs please pm me or see
and may she (or bits of her) live again.
SWMBO is currently eyeballing a Xara on eBay ath the mo so I may be around the forums for a bit longer.
MikeM
x 5672
Why not just drop a replacement engine in Mike?
Chris570
x 36
Unread post by Chris570 »
i have an engine out of a 95 td xantia that you can have cheap if that helps
MikeM
myglaren wrote:Why not just drop a replacement engine in Mike?
Thought about it for all of 2 seconds. Really, I'd love to and I know I'd enjoy doing it but I just don't have the facilities to do another major job. Not to mention the cost of the clutch and gearbox and CVJs which I would definitely want to do at the same time.
Time is the other factor, SWMBO needs a legal motor within a couple of days not the 2 weeks to a month I would undoubtedly take.
If anyone wants her (the car not SWMBO) to do themselves get in touch quick before I start breaking.
MikeM
x 8391
Sorry to hear what happened Mike :(
Still, rather than just carting her off to the knackers, you're offering lifesavers to others and that's good. Not died in vain.
Any views or thoughts on what caused the engine to die so catastrophically? It's a relatively unusual failure for a conrod (I presume it was a conrod) to let go.
There was a case of a batch of bad Conrods in some DHY (I think) engines but as far as I know they were never in any Xantias; used in some NA 306s if the old memory is good...
MikeM
CitroJim wrote:Sorry to hear what happened Mike :(
Not sure Jim. I haven't looked inside yet but there is a gaping hole in the front and something came through far enough and forceful enough to destroy the starter motor into the bargain.
Looking down through this hole can be seen a big end although not much detail about it's condition or whether it's still connected to the crank, but it's also possible to see past the big end through a hole in the sump to the ground so more damage below too. (I'm assuming that the sump is still there)
MikeM
MikeM
CitroJim wrote:Any views or thoughts on what caused the engine to die so catastrophically? ...
I got someone showing interest in the cylinder head, so if I do take that off I'll be in a better position to see what went wrong and let you know.
I have to admit, the curiosity is killing me - I hate not knowing!
MikeM
KP
x 27
Unread post by KP »
Sad news Mike.
Sounds like the conrod came away from the piston and has punched out two holes before it was stopped.
Very rare to see that on a xantia. Seen it on 1 transit once that still kind of ran on 3 cylinders enough to get me to the Ford dealership.
The van did spend the last 5 months before that doing 40 miles each way up the M6 with myfoot firmly on the floor to keep its speed up which probably didnt help!
x 8391
My lad put a conrod through the side of the block in his first car, a Fester 1.25 Zetec.
It was his own fault. The car used oil and he used to leave topping up until the oil light came on going round corners.
One time the bonnet stuck shut and he drove it home from Cardiff with an almost dry sump. I refilled it but the damage was done.; it was knocking a bit..
He took it back to Cardiff and a week later it expired at 70MPH. Bang!
Conrod straight through and into the side of the starter funnily enough. Wrecked the starter.
The car lives on to this day following an engine transplant.
Dommo
x 20
Unread post by Dommo »
There's plenty of 1997-early 98 306's with 'the dreaded DHY' engine where they've thrown a conrod through the block. This is the only reason I'd never own an R reg xud engined car!!
