Drilled Airbox Mod - XUD9
birlengo
I drilled the stock airbox with 6 holes that are about the size of a 2p coin. I noticed increase in torque throughout the rev range, and much more spirited drive from the engine, when downshifting and maintaining speed in high gears.
On the downside, it is not very economical now! I blocked 3 holes to increase economy and it seemed to have done the trick. I am suprised at how much extra power that gave the engine; thought I would share that with you lot.
BTW it is a non turbo XUD9 fitted to a Citroen Berlingo.
XantiaMan
- x 18
- x 8427
DickieG
- Monaco's youngest playboy
- x 33
- x 8427
I'm sure one exists, somewhere...DickieG wrote:I've not had first hand experience of a V6 Berlingo, tell more JimCitroJim wrote:Even the V6 has a nearly identical setup and that's perfectly good for near 200BHP....
It would be rather awesome, along the lines of Brigsy's Renault van
spider
- x 77
The only way I can think of that 'might' increase power (although it would increase noise) if the air box was drilled would be the entry of more cold air.
I'm just thinking along the lines that cold air = denser so the same principle the intercooler works in a way...
Andy.
XantiaMan
- x 18
And where would this cold air come from? Last time i checked, engines generated heat and this heat sits in the engine bay, and even once moving, the heat will radiate around. Want cold air? Get it from outside the car, from the grille for example.spider wrote:The only way I can think of that 'might' increase power (although it would increase noise) if the air box was drilled would be the entry of more cold air.
spider
- x 77
XantiaMan wrote:And where would this cold air come from? Last time i checked, engines generated heat and this heat sits in the engine bay, and even once moving, the heat will radiate around. Want cold air? Get it from outside the car, from the grille for example.
I just sort of meant that cold air = denser = more power same as an intercooler. That's the only possible explanation.
Top mounted intercoolers have the bonnet 'guides' anyway, but I know what you meant
No, I do not intend on drilling my airbox, although I keep thinking about popping an intercooler on (although space is a little tight for that on my 205)
Andy.
birlengo
LoL, ok people doubt me if you want.
I will have to take a pic tommorow morning so you get a better idea. It has improved performance and it had decreased economy I know that from driving it, and so would anyone else who drives the van.
I blocked three of the holes and got a nice balance now, believe me or not it does give the van some low end power. Even on any petrol car if you drill the airbox like I have it will increase performance, this is a common simple mod.
Xaccers
- x 188
More air would improve economy wouldn't it?
You're getting more fuel burning as there is more oxygen available, so more power with less fuel.
DIY sphere tool
DIY sphere tool
XantiaMan
- x 18
This thread is silly. Warm air, less dense, less oxygen, less power. Fact.
This is a simple but badly thought out mod often carried out by chavs in Saxos wanting to sound like they have an induction kit on their 1 litre lawnmower engines.
Spider, if you didnt mean the entry of cold air and meant increase the volume of air then this is again unlikely, because the engine can only suck a certain volume of air, and if the airbox is good enough on a V6 it wont be causing ant degree of restriction on a 70bhp ATMO diesel.
Simple test to see if you have increased your performance to any degree.
Find a good clear stretch of road. Find a starting point, i.e a lamp post as a marker. Go along at 20mph in 2nd gear (as an example) when you pass the lamp post. Set another marker point 15 seconds or so ahead. When you have reached this end point, note the speedo reading.
Try with the holes sealed up, and try without. Then come back and say if your van IS actually faster or just sounds faster.
BTW, the increase in economy will be you putting your foot down more, and driving in a more spirited fashion. Its all a placebo effect. Atmospheric pressure has way more influence on day to day performance than people realise, especially on a non-turbocharged engine. Air pressure has gone up significantly in the past 48 hours and can account for a perceived increase in performance.
robert_e_smart
- x 14
It'll be this one then...I've not had first hand experience of a V6 Berlingo, tell more Jim Laughing
http://cgi.ebay.co.uk/2001-CITROEN-BERL ... 4a9fdcb8a6
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
1991 BX 16 TGS Auto
birlengo
you can sit here and discuss it all day, but you are not driving this particular van. I drive the van daily and I keep an eye on fuel economy whilst I have been testing the airbox by blocking holes etc; and I have seen an increase in acceleration.
LOL at everyone getting excited about the noise, as a matter of fact the noise as not increased, it it not noticable at all; even if it has got louder!
steelcityuk
Toby_HDi
- x 3
Don't forget the electric supercharger!...steelcityuk wrote:Try fitting a vortex induction ring.
They work like a charm - ie. Lucky charm if you believe it works then it must.
A set of those fuel magnets would really top off the job.
To really prove if it works as advertised an independent rolling road is best.
Steve
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
