water under xantia rear seats
Any idea where this is from? It seems to build up even when theres no rain
Love my black v6 xant - only one with cream coloured leather too!
I had a similar problem, it turned out to be partially blocked drain holes in the hatch lid. Do you have water under your boot carpet?
Also worth checking where else you have water. It will cause havoc with your electrics.
Under the front seats there is a place where the front and rear carpets overlap. Stick your hand in there, if it's wet you may well have other leaks too.
I had a leaking scuttle panel that filled my Xantia up...
Fingers crossed, I'm water tight now.
95 Xantia 1.9TD SX - Now sold
- My Cars: Peugeot 806
Citroen C3 1.4 Hdi - x 4
