Xantia Pitching & Rolling
mikep
Unread post by mikep »
Xantia 1996 1.8 auto
Have noticed my Xantia is pitching & rolling excessively when cornering, it's 13 years old, is there anything I can do to reduce this ?
mikep
Citroen Xantia auto sx 1996
x 5672
Swap it for an Activa? :twisted:
mikep
very helpful !
mikep
x 1459
Unread post by xantia_v6 »
It is hard to tell from your description if your car is behaving in normal Xantia fashion, or something worse.
mikep
I think the word 'excessive' answers your question.
mikep
Xaccers
x 188
Unread post by Xaccers »
what spec xantia? lx sx vsx?
when were the spheres last changed? check the numbers to ensure the right ones are fitted. garages have a nack of getting them wrong.
same with tyres, are they the right side wall rating and inflated properly with plenty of tread?
when did you last perform citrobics or change the lhm and clean the filters?
have you looked underneath with the car securly supported for anything that could be loose?
DIY sphere tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
OP wrote:Citroen Xantia SX Automatic 1761 CC 31.08.1996
I'd say flogged out droplinks and swaybar bushes might be contributing.
mikep
Thanks, I'll have your suggestions checked out.
mikep
Old-Guy
x 24
Unread post by Old-Guy »
If the problem suddenly appeared, perhaps one end of a droplink has failed entirely?
x 1240
Unread post by Peter.N. »
You could fit hydractive spheres - trouble is though it would almost stop the suspension moving at all.
