XM Prestige
harryjoe
XM Prestige
Unread post by harryjoe »
Evening all.. :lol:
Just need to pick your knowledgable brains on an early XM.
Is there anything in particular that the earlyer one's suffered with ? as i believe 1992 was the 1 st year of production ! ( i could be wrong ) :oops:
Iv'e been offered what looks to be a nice one, and very low mileage, but just wondered if they had many teething problems that i need to be aware of.
It's a 2ltr petrol, with aa good service history.
Any thoughts :wink: :wink:
1998 Xantia 1.8i 16v Auto (sold)
1997 Xantia 1.9 TD Estate (Resting with 231k) zzzzzz
1989 BX 19 RD (In a barn awaiting TLC)
2002 C5 2.2 HDI Auto Estate (Sold)
1994 XM 2.0 Turbo (Sold)
1983 Bertone X1/9 VS
1995 405 1.8 GLX Estate (sold)
2000 Xantia Estate 2l HDI 110K
Deanxm
x 87
Unread post by Deanxm »
Hi
This age will be what is known in XM circles as a MK1.5 n/a petrols got a full injection and ignition computer rather than having a dizzy and so gained a bit of power, there were earthing mods and a rather bland two spoke wheel.
things to watch for are damaged and rusty sills, especialy at the back, make sure the hydractive works and you can feel it switch from sports to normal mode with the switch by the gear lever, if its auto you should be seeing good clean red transmission fluid in the dipstick and preferably some service history to prove regular maintenance of the box, you should also see clean bright green LHM in the hydraulic resovoir. Apart from that its just the usual stuff to check for.
First year of manufacture was 1989 by the way with the facelift MK2 coming into production at around M reg, 92 to 94 were MK1.5 and are regardeed as the best age by some, keeping the original wierdness with increased reliability although by this age its almost irrelivant as any problems will have been delt with.
Regards
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
harryjoe
Thanks D, for the advice :D
Yes iv'e just done i bit more digging , and 1989 was the 1st year :oops: :oops: ,
as for the sport mode on the suspension, when switched to that mode, can you feel any differance while just at idle, or only when moving ?
sorry to sound a bit thick about this, but not had an Xm before so they for me are new territory.
I will check all oil's when i see it , but it is supposed to have a full history,
it's only covered 80000 miles !
Thanks once agian
Nigel
Citroenmad
x 110
Unread post by Citroenmad »
Well if its a true S1.5 it will have hydractive 2, which will only cut in when it needs to. However early S1 cars have hydractive1, which is in when selected is in sports mode all of the time.
To test its working, open the cars door and there should be a buzzing noise, this is the ECU in soft mode, the car should feel soft to push up and down. Then shut the door, after a short time (i forget the exact figure, i need to remember it! a minute or so) the buzzing will stop and the car will be in sports mode, then it will feel harder to press up and down. This is without the engine running.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
harryjoe
Also , as it's a Presige, what are the differances on trim and toys, over or under say an exclusive ?
Ive had a look around on tinternet, and can't find any info on the trim levels . !
Nigel
Deanxm
x 87
um MK1.5's had both hydractive 1 and 2 fitted they bridged the changeover period, but neither will enter sport at idle, whilst driving the difference should be very noticable if all is well with hydractive 1.
Prestige was basicaly base spec cars garnished with leather, A/C and digital climate plus a few other goodies like Ettoil alloys and abs.
D
XM Prestige PRV6 92
Deanxm
x 87
mine has all the above including electric windows, electric sunroof, heated electric mirrors, unheated manual leather seats, IR remote central locking and alarm so not a bad spec really.
Dean
XM Prestige PRV6 92
harryjoe
So all in all , not a bad spec then :D :D
It sounds like it will have enough toys in it for me !,
just an other quikie :wink:
Does the secorndary glazing on th rear hatch come as standard, or only on curtian models??
cause some i have seen, havn't got it, just wondered if it was down to the model.
Thanks Guys
Nigel
Deanxm
x 87
yes its down to model, the prestige does not have it but if you can find one it can be fitted, i got one for mine but you need the rear roof trim with the bulge's to cover the hinges too, not something that comes up that often but they are about.
D
XM Prestige PRV6 92
x 1240
Unread post by Peter.N. »
They are a very nice car but its unlikely you will buy one that doesn't need some attention, I've been buying them for years and all mine have. Unless the suspension spheres have been replaced recently, a new set will do wonders for the ride, there are seven in all, including the accumulator sphere, you can buy the whole lot from GSF for about £160.00, but if you don't want to replace them all, the centre front and rear spheres will make the most difference to the ride.
Deanxm
x 87
The thing we both forgot to say is that there is loads of info on http://www.club-xm.co.uk/forum/index.php
if you do a search there is lots of info on trim and the car in general too for you to look over.
D
XM Prestige PRV6 92
x 1240
I believe the only dedicated XM forum :D
harryjoe
Thanks to all of you for all the information :lol: :lol:
I tried to get the club Xm site up before, but kept saying host error, so il'l click the link, 'n' have a good rumage :D
Cheers Guys
harryjoe
Oh , just to mention , that the spheres where all regased back in2009 + cambelt, so shouldn't be any problems there ......
Gunna take a look at it on saturday.
Il'l keep you posted :) :) :)
citroenesque
x 4
Unread post by citroenesque »
Best of luck. Don't forget to check lights and washers.
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
