Hi everyone.
For sometime now my V6 has on occasion been 'ticking' as in perhaps one Hydraulic Tappet, this is now quite loud (especially as I now have a new exhaust system fitted) it 'comes and go's' as if the tappet rotates BUT it doesn't increase in tapping rate with the engine speed. A slight increase in throttle pressure can sometimes result in a jump in ticking speed for a few seconds. Under the bonnet it is quite difficult to hear it, I don't think it is the accumulator sphere, it seems to be on the nearside though. Anyone else experienced similar?
Ian
Xantia V6 'Ticking'
f00lzz
Xantia V6 'Ticking'
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Sid_the_Squid
Hi Ian,
If its a rapid ticking, which is totally unaffected by engine RPM, comes and goes at what seems like totally random times, then I'd say its the carbon canister valve doing its thing. Totally normal
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
f00lzz
Oh good! thanks for the speedy reply.. any idea where it is located, I would like to be able to confirm it as the culprit.
Ian
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Sid_the_Squid
If memory service me correctly its up front near the battery, its findable on the mk2 by following one of the vacuum tubes from the throttle body. On the mk1 I think its really buried to the point of having to take the wheel liner (is that the correct term?) off to access. Never done a mk1 myself this is from memory of watching Jim working on his V6.
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
Dommo
- x 20
- x 8391
Depends if it's a MK1 or a MK2. On a MK1 it's buried in under the wing and thus inaudible. It's where you say it is on the MK2 though Dom and they can make a racket.
Mine ticks occasionally. When cold and idling. Just a touch of revs and it clears, never to return. That is a tappet, no doubt about it, but at nearly 169K I'm not over-anxious about it.
Mine ticks like a ten-bob watch after switching off when nicely hot. That's just the exhaust cooling down..
Ian, is the ticking only there when cold?
f00lzz
No Jim.. it can be audible when cold or hot and is definately seems louder inside the cabin... I'll have a go at recording the sound and post it on here.
Ian
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
f00lzz
Hi
OK I have found it.. you can actually feel the small brown cannister pulsing which corresponds with each 'tick'. I recorded the sound but can't see a way to upload it so here is a photo.. it is located just in front of the battery (you can see the battery clamp in the pic) thanks for putting my mind at rest.
Ian
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Dommo
- x 20
Sid_the_Squid
Yep that's the valve I'm on about, nothing to worry about there Ian, just let it tick away
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
lexi
- x 133
f00lzz
I'm seriously considering moving it or insulating it... it's embarassing, my passengers think there is something wrong with the engine. I have explained that Citroens don't have faults, they have characteristics!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- x 8391
On the Mk1 Ian, it is both wrapped in high density foam and buried under the inner wing. That applies to the MK1 Activa and V6.f00lzz wrote:I'm seriously considering moving it or insulating it
Strangely, where the MK2 valve is located, the MK1 has a straight joint in the pipework; almost as that was where it was going to go but for some reason, they decided at the last minute to move it under the wing..
