Just wondering if anyone, anywhere has come across silicone hose's for the xantia. be it cooling system or air inlet system?
Also does anyone know if a lower temp thermostat is available or is it a case of knocking the guts out of the current one and fitting an inhose stat thats a lower temp?
Cooling system queries
OnlineCitroJim
- x 8441
Hi Will,
No idea on the silicone hoses but plenty of companies will make bespoke ones. Have a look in Practical performance Car, always loads of adverts for them.
The thermostat in the CT should be an 83 degree one. These are available although you'll need to go to a factor and check his parts catalogues carefully. Usually they'll offer the standard 89 degree one by default.
It makes a differeence running the cooler 'stat.
KP
- x 27
Dommo
- x 20
Euro Car Parts stock an 82 degree thermostat:
http://www.eurocarparts.com/ecp/c/Citro ... e661c&TSTA
