DW8 Poor starting
jonnydrumm1967
DW8 Poor starting
Unread post by jonnydrumm1967 »
Friend has a C15D 2001 1868cc. It's become a very poor starter,He's replaced the battery,starter motor and glow plugs but to no avail. Are these engines bad for the valves closing up and losing compression?
Once it has started,it will start all day long no problems there.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Maybe the fuel system is drawing in air. Use the hand primer until it's solid then immediately try a start. If it goes, start looking for the source of the leak. Maybe around the banjo joints.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
spider
x 77
Unread post by spider »
I don't think the DW8 suffers from the closing valves problem, I've not really heard of it on this unit before (but there are exceptions I suppose and any engine could do this)
It's only the XUD7 (thanks to Jim for confirming that even with these its the N/A one's only)
I'd initially go with the air in fuel theory stated by JohnD, press the "button" type plunger these have a few times, then try to start it again.
Off topic, but I was not aware they used the DW8 in the C15, I (assumed!) they kept using up the XUD7's in this only...
Andy.
