As above, my intermediate bearing is sounding rough so looking to replace the shaft.
Phoned dingbro and they say theres 2 types depending on how many splines the inner shaft has.
So my question is does anyone know this before i have to go and remove the shaft to find out.
I would prefer to know becuase they only have one type of shaft in stock.
Any helop is much appreciated.
The car is quetion is a xantia 2.0 HDi 2001 X plate hatchback
O/S drive shaft on xantia HDi
citroenxm
- Fallen Hero
- x 70
You should have asked yesterday, I had an off side HDi shaft out from the box trying to sort a ABS Ring out on CV joint, why did I remove it? I was going to fit a later FAT SHAFT from an XUD, but even these are slightly smaller to the HDi shafts...
Incidentally, that intermediate shaft from the box to the bearing is feather light! I think they are hollwed out!
Defenatly half the weight of the older XUD shafts!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
scoles
Ah i was going to ask yesterday but thought i would find it on here somewhere, or the net...
I have found something somewhere that fits citroen dispatch Mpv
Internal spline count 37
External spline count 27
ABS teeth 48
Compressed length 941mm
I was thinking on calling them back and seeing if this resembles the one they have in stock.
Stuart
ABS teeth 48
Stuart
fred1
